Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Good engine choice
Old Jan 4, 2010 | 10:20 PM
370 RAM AIR's Avatar
Default Good engine choice
Ok guy's i have a 85 gmc SWB with a 305/700r4 set up i want to go bigger .i want to have good power at the wheels and still have a DD .right now i have a 97 vortec 350 blk with the heads and a set of .30 over pistons i was planning on going with a xr288hr cam .would this set up be good or should i go a differnt way
Old Jan 4, 2010 | 11:05 PM
POPO1984's Avatar
Dude we are in the same boat
Old Jan 5, 2010 | 07:38 AM
big hammer's Avatar
that's too much cam for a DD. plus you will have to re-work your heads to accept that much lift.
the xr268h is about as big as you wanna go. i was able to run this cam on a stock set of vortecs and it worked very nice, but the lift was really maxxing the heads.
Old Jan 5, 2010 | 07:41 AM
[QUOTE=big hammer;12706957]that's too much cam for a DD. plus you will have to re-work your heads to accept that much lift.
What would be a good cam for it it's gonna be some what of a daily driver i live 7 miles from work i just want to have a good motor with *****
big hammer's Avatar
but if you want to keep the engine a roller then use a cam with .480 lift MAX and keep your duration in that 220-230 @ 50 range
Old Jan 5, 2010 | 07:45 AM
big hammer's Avatar
[QUOTE=370 RAM AIR;12706960]
the xr268h is about as big as you wanna go. i was able to run this cam on a stock set of vortecs and it worked very nice, but the lift was really maxxing the heads.[/QUO What would be a good cam for it it's gonna be some what of a daily driver i live 7 miles from work i just want to have a good motor with *****
remember not to over cam your engine. it's a common mistake by many new engine builders. the result is a poorly running engine and under performing
you may want to look at putting in a 2000-2500 stall torque converter while your in there
or just find a 400 small block and have the best of all worlds!
oh and if you use the 97 block, you're gonna need a new flex plate. the 1 piece rear seal crank wont accept the older 2 piece seal design crank flex plate
Old Jan 5, 2010 | 07:46 AM
Would it just be easier to sell this engine and just install a 6.0
Old Jan 5, 2010 | 07:49 AM
[QUOTE=big hammer;12706972]
i have a friend that has a 400 laying around give me some ideas for it
Old Jan 5, 2010 | 12:43 PM
Would i be able to use the piston on a 400
Old Jan 5, 2010 | 01:10 PM
87silverbullet's Avatar
Nope. Stock piston size in a 400 is 4.125.
The 400 with the vortec heads(make sure you have them machined for higher lift) and a XE274 (230/236) from comp will make a good lil street motor in that truck. You could put an XE268 (224/230) and be on the tamer side.
Old Jan 5, 2010 | 01:13 PM
What HP would u think i could get with the 400 and vortec heads
Old Jan 5, 2010 | 01:17 PM
If I remember right, CHP (Chevy High Perf. Magazine) did a 400 build with the xe274 and vortec heads and made 440 hp or somewhere in that neighborhood. They later put on a set of AFR's and made 480.
Old Jan 5, 2010 | 06:36 PM
big hammer's Avatar
and probably 450 ft\lbs torque with that too!
Old Jan 5, 2010 | 06:37 PM
big hammer's Avatar
the 268 is almost too tame for a 400.. but good in a 350. the xe274 in a 400 would be just nice
Old Jan 12, 2010 | 09:16 PM
fox16's Avatar
to the back tire?
Old Jan 13, 2010 | 04:38 PM
No that was at the crank, but if I remember right that was on 87 octane. Let me do a lil research and I will post it up.
Edit: It was a Lunati BracketmasterII cam 230/230 480/480 lobe sep. 109. It made 490 hp at 5600 rpm and 529 ft lb at 4100 rpm
http://www.chevyhiperformance.com/te...ild/index.html
Old Jan 13, 2010 | 05:31 PM
quews6lime's Avatar
good choice
