how easy is it to hit 350hp?
is it possable without spending over $650?btw i already have the motor..this is if my dad lets me use it..if not im using the 350 out of his truck with votec heads
vortec heads, eddy stage 1 street strip intake manifold, 750cfm carb, maybe balance the internals if i have money, all new gaskets, cam (not sure of the specs yet) headers, summit distributer, coil, and ignition box, aluminum pullys, and get the engine dynoed and tuned up...
and as i said then connected to a t5 with a aluminum flywheel, zoom clutch, rebuild the trans, maybe aluminum driveshaft, and stock ls1 rearend with lsd and 3.42 gears..
i think its a solid setup that shouldnt cost more than 2grand to do..maybe 2500-3000..
no need to balance the internals on this project, it wont be a screamer.
a 670 carb should be all you need.
