Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
another BBC 4th gen
Old Mar 9, 2010 | 11:35 PM
phoenix's Avatar
Default another BBC 4th gen
Well i gave up my LS2 402 turbo build and going BBC.
here is the setup so far
BBC 468
callies crank
lunati rods
13:1 c/r
Patriot Freedom Heads
278/295 @ .50 789/799 112 lsa
team G intake
1050 alky carb
going to hit it with a 400 shot direct port.
so far i have less then 5k into the moter build
Old Mar 10, 2010 | 03:24 AM
ZONES89RS's Avatar
In-Zane Moderator
Gotta know, how do you do the motor plate? Do you have to use a WP gasket on both sides of the plate?
Old Mar 10, 2010 | 11:40 AM
trigger1's Avatar
Looks good. Similiar to what I'm doing.
Old Mar 10, 2010 | 02:04 PM
BassProCamaro97's Avatar
Looks good.
What are the goals for the car?
~Jim~
Old Mar 10, 2010 | 11:54 PM
phoenix's Avatar
You have to se some kind of gasket on both sides, or atleast i am.
Originally Posted by BassProCamaro97
Looks good.
~Jim~
i am hoping to break into the high 9's on motor and high 8's on spray.
depending on how the car runs will depend on what class i am going to run.
Old Mar 12, 2010 | 01:40 PM
TooLateVTEC's Avatar
I was thinking God damn thats a lot of cam for only a 468 until I read the 400 shot part, lol.
Nice car man.
Are you stickin a real motor in the mustang as well?
Old Mar 12, 2010 | 01:54 PM
smok'nZ's Avatar
MASS seller approved
cool set up BBC's are way cheaper than LS set ups
Old Mar 12, 2010 | 05:25 PM
phoenix's Avatar
i dont know about way cheaper but its easier to come by parts thats for sure.
Nice car man.
Yea I thought it was a lot of cam also when they comp cams spec it out for me, he said it will really wake up on spray so that is what i want.
The stang is geting a turbo LS1
Old Apr 5, 2010 | 04:37 PM
killersmechanics's Avatar
hey guys i have a 402 big block in my 1985 2door box chevy with plate and fogger just finish up with motor but have 9inch ford rear need help with hooking wat should i do motor is 60 over small dome pistons eagle crank and rods roller rockers it has the works u tell me killersmechanics@gmail.com
Old Apr 5, 2010 | 06:54 PM
HioSSilver's Avatar
why???? The ls motor is way better
Old Apr 6, 2010 | 12:07 AM
ls1foxcoupe's Avatar
What headers are you using?
Old Apr 6, 2010 | 10:11 PM
phoenix's Avatar
I am using the Hooker 2241 headers, they should fit just have to notch the frame rail a little. Once i get the motor back and get the headers installed i will post pics.
Old Apr 6, 2010 | 10:16 PM
phoenix's Avatar
i agree the LS motor is a great motor, but a long story short the big block just comes out to be cheaper
Old Apr 9, 2010 | 01:10 PM
BBC's Avatar
BBC
I used 2241 headers as well and they fit pretty well with the BMR K-member. I had to make one slight change to them on the passenger side because they hit the firewall on one tube. I know this is slightly off topic but the TH400 dipstick tube works really well from Mad Man for the big block. If you are just beginning this conversion you will really appreciate the items that just fall into place.
Old Apr 9, 2010 | 11:47 PM
phoenix's Avatar
by any chance you have any pictures of the headers installed?
Old Apr 15, 2010 | 07:27 PM
steveo346's Avatar
cant wait to see this build come to a finish.
one pregunta though, why is your bay spray painted flat black?
Old Apr 16, 2010 | 12:34 AM
phoenix's Avatar
the car was black, I had it painted SOM. that is one of the things i want to hae done while the motor is put, but i would rather spend the money else where.
Old Apr 16, 2010 | 05:30 PM
NemeSS's Avatar
a built bbc should warrant a mid 9 pass n/a or better in any car imo.
will run strong for sure, i woulda went with the turbo ls
Old Apr 16, 2010 | 07:36 PM
phoenix's Avatar
oh im sure the turbo setup would have run strong but i still think the BBC was a better choice. I lost a LOT of money changing setups when the turbo setup was pretty much done.
Old Apr 18, 2010 | 10:16 PM
littlefranks's Avatar
