Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
rebuilding procharged 383 advice
Old 03-29-2010, 09:16 PM
bryan23's Avatar
Default rebuilding procharged 383 advice
heres the parts already have:
gm zz 383 block 880 block
-226/238 with 558/560 114 lsa custom brand new lunati hydraulic roller cam
-3.80 4340 gm forged crank
-fast burn gm heads with gm 1.5 roller rockers
-superram intake with 52mm throttle body
-procharger d1sc
Parts that i thinking of getting
-scat h beam rods
-forged custom diamond pistons with 8.5 to 1 compression
-arp main studs
-arp head studs
-efi connections obdII lsx computer system
shooting for 600ish hp with about 15pounds of boost on pump gas? sound reasonable anything else i should get?
Old 03-29-2010, 09:37 PM
In-Zane Moderator
ZONES89RS's Avatar
Man, looks like you are on track, you should see 700 RWHP if everything is correct. Give or take, a BS tune will get 600 pretty easily i think.
