Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Is this enough thread on rocker stud
Old Apr 26, 2010 | 09:43 PM
EL T1's Avatar
Default Is this enough thread on rocker stud
I've had a rocker stud break on my engine for the second time (two separate ones). The heads have been on a bout a year and a half. Vortec heads, 1.5 RRs, upgraded springs, screw in studs/guidplates. The stud snapped in half at the lock. Is it beacause there is too much stress on the tip of the stud? Any ideas? experiences? Thanks
The pic is of the new stud. Thats how much thread coming out of the rocker arm. Is that normal. Sorry cell phone pics. I can better ones tommrow
Old Apr 27, 2010 | 09:34 AM
cambirdracing's Avatar
The stud should go into the nut at least the diameter of the nut. Example, if your stud is 3/8, then it should go into the nut 3/8. If it is 7/16, then it should go into the nut 7/16. Great rule of thumb, the more in threads in the better.
Old Apr 27, 2010 | 09:57 PM
kenSS's Avatar
run it.
Old May 4, 2010 | 03:19 PM
HonkifPartsFallOff's Avatar
What brand studs are you breaking?
How much lift? how much clearence do you have between the retainer and guide or valve seal? What type of lifters? and if they are hyd lifters how much are you preloading the plunger?
That looks like plenty of thread engagement.
Old May 4, 2010 | 08:26 PM
big block camaro's Avatar
buy stud gidles studs wont break
