Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Gen1 355 conversion!!!!
Old Apr 28, 2010 | 08:46 PM
ats5424's Avatar
Default Gen1 355 conversion!!!!
Finally underway with my 355 build for my 95 M6 Formula. Here is the parts list.
355 11.2:1cr shortblock(CNC-Motorsports).
Dart Pro1 Aluminum 230cc heads. 2.08/1.60.
Dart single plane race manifold.
Comp Solid Roller (.582/.588) (292/297) 3200-7200 Cam. XR292R.
Comp Endure X Lifters.
Jegs 1.6 Aluminum Rockers.
Proform 750cfm Mech. Secondary Carb.
Proform Electric waterpump.
Jegs 105GPH electric fuel pump.
Old Apr 28, 2010 | 08:47 PM
ats5424's Avatar
How do you post Pics?
Old Apr 28, 2010 | 09:05 PM
ats5424's Avatar
Old Apr 28, 2010 | 09:10 PM
ats5424's Avatar
https://ls1tech.com/forums/picture.p...ictureid=47450
https://ls1tech.com/forums/picture.p...ictureid=47452
https://ls1tech.com/forums/picture.p...ictureid=47451
https://ls1tech.com/forums/picture.p...ictureid=47453
https://ls1tech.com/forums/picture.p...ictureid=47454
https://ls1tech.com/forums/picture.p...ictureid=47455
https://ls1tech.com/forums/picture.p...ictureid=47456
https://ls1tech.com/forums/picture.p...ictureid=47457
Old Apr 28, 2010 | 11:17 PM
camaroboricua's Avatar
Sounds like its going to be a really nice set up. I want to see what you are going to do for an air filter with such a tall intake manifold. Cant wait for the build pics.... :-)
Old Apr 29, 2010 | 10:55 AM
IAmTheSTIG's Avatar
nice build, but i would definitaly get rid of those jegs rockers.
Ran them on a 383 and a bunch of them were destroyed.
Best bet is to try and find some harland sharp shaft mount rockers, that's what i'm going with on my 434 sbc.
that top end looks familiar to, same thing i'm going with as well, dart 230's with a little more massaging in the ports, 274-282 @ lift, .630 solid roller cam on 108 lsa. i'm a big fan of the dart stuff, done me well in the past.
Old Apr 29, 2010 | 03:01 PM
BassProCamaro97's Avatar
Looks pretty slick.
I wouldn't worry to much about the tall manifold. I'm running a tall brodix manifold and a Holley 1050 dominator under my 3" cowl.
I'm guessing with this type of setup you would be running a non stock hood as well.
~Jim~
Old Apr 29, 2010 | 09:25 PM
ats5424's Avatar
Yea i figured that the stock hood wouldn't work with this setup. Im not too sure what hood im going to go with. Ima take a look at the height once the engine is assembled and installed. The bottom end is going to take 6-8 weeks to build so its going to be a while until i have some engine build pics, but i'll post pics of everything in the mean time. thanx for the interest.
Old Apr 30, 2010 | 07:33 AM
pancherj's Avatar
That seems like way too much head for a 355 with that cam...or not enough cam. It should run real strong, but you might be leaving some on the table. Those heads on a 406-434 sound about right.
Old Apr 30, 2010 | 11:23 AM
moge11's Avatar
those heads dont flow worth a damn outta the box... A bowl-blend, trim the guide boss down, and LAY THE SHORT SIDE RADIUS bacK, will DO WONDERS! also open up the pushrod pinch.. all of this will bring a 265cfm head to well over 300cfm...
Old May 29, 2010 | 05:58 PM
merim123's Avatar
couldn't you just run the stock intake (ported)?. since you are converting from lt1, couldn't you could run the lt1 intake and fuel injection and for ignition tap the manifold in back for a distributor. that in my mind could be best of both worlds maybe? you eliminate opti, you go sbc gen 1 and you keep lt1 computer fuel, etc... don't know...sharing some thoughts...
Old May 30, 2010 | 09:19 AM
Rogue86's Avatar
A 110 gph pump probably won't keep up with the rpms you'll need to turn the motor to run those heads on a 355.
Old Jun 6, 2010 | 06:39 PM
ats5424's Avatar
Im still waiting for the bottom end to come in, doing some wiring in the mean time. Ready to get it going so i can post some more pics, and get some dyno numbers. What im going to do is bolt the heads and intake on right out of the box, break in the engine, and then go and have the car dynoed. Then im going to take the heads and intake back off and send them to Meaux Racing and have him port the heads and intake, then redyno the car and see the difference. I'm curious to see the difference.
Old Jun 6, 2010 | 07:01 PM
moge11's Avatar
Larry Meaux is an AWESOME Head Porter. If u do that, this car is gonna straight rock n roll!!!. mid ten at 125+... its gonna want a lot more cam and RPM... you really need to turn it close to 8000.
Old Jun 7, 2010 | 07:54 PM
ats5424's Avatar
Yes he does really good work, his shop is only about 30 monutes from my place so thats pretty nice.
Old Jun 17, 2010 | 05:53 PM
ats5424's Avatar
The engine is finally finished at cnc-motorsports and is in route to my dads shop. It is supposed to arrive on Tuesday. I have all of the parts ready to go so i will soon have more pictures and a video to share with everyone.
Old Jul 11, 2010 | 07:43 PM
ats5424's Avatar
Sorry i havn't posted in a while. Working hard to get this finished, anyway here are some pics of the engine.
Keith Black Aluminum .30 Overbore Pistons
Old Jul 11, 2010 | 07:44 PM
ats5424's Avatar
Eagle 3D ESP H-beam rods
Old Jul 11, 2010 | 07:45 PM
ats5424's Avatar
Starting to come together
Old Jul 11, 2010 | 07:47 PM
ats5424's Avatar
