Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Help With Head Choice
Old Jul 7, 2010 | 07:09 AM
87silverbullet's Avatar
Originally Posted by F-Body Lover
not every country got the same set up in my country they just remove the guide plates and put large pushrods and they didnt even bend one pushrod or broke a rocker but putting guide plates back is safe side its like the saying "better safe than sorry"
Well you can't assume we have the same thing here. The heads you get from Scoggin and Dickey do not come with guide plates. They come from the factory on 1996-1999 trucks without guide plates. Self-aligning= less hassle
Old Jul 7, 2010 | 07:31 AM
Originally Posted by The Guy in MY 99TA
I'm not sure that the hp numbers you have been told are going to be as close as your hoping... I'de say a little closer to 350. the vortec heads are great heads for a budget build but they really need a good port job to shine. Its not hard to make 400 hp w/ vortec heads though. I've seen some make 500 w/ vortec heads and 2 barrel carbs(dirt track engines)
but saying a comp 292 camshaft doesnt give enough info... you can get a couple of different comp 292 cams. is it a hydraulic or solid? which grind? comp has about 5 different grinds of camshafts.
Going by his lift and duration numbers it is the magnum292h grind, it is a flat tappet hydraulic cam. It will make decent power and a good bit more than 350 hp
Car Craft did a untouched vortec headed build and made 440 hp with a comp extreme energy grind. Here is the link.
http://www.carcraft.com/techarticles...ine/index.html
Here are the specs on the cam they used.
http://www.compcams.com/Cam_Specs/Ca...x?csid=87&sb=2
Old Jul 8, 2010 | 08:51 PM
LoStOCeAnZ63's Avatar
well hopefully ill be around the same power that would be SAWEET!
Old Jul 8, 2010 | 09:01 PM
pictures of the car the motor is going into
Old Jul 13, 2010 | 05:32 AM
so i should be making around the same power at the crank?
Old Jul 15, 2010 | 01:47 AM
i got my hands on a chevy s10 with a 383 small block in it Kb 10.5.1 compression 488 lift cam air gap manifold 750 carn msd distributor long tube headers camel hump heads turbo 350 with a 4000 stall converter im going to pull the motor out and put it in my el camino and then put my 350 in the s10 and sell all of the rest
the motor in the s10 has o miles besides what i put on it coming home he said it should be making around 360-370hp im wondering if i put my 292h cam and vortec heads on it what kind of power id be making then? im using this motor for a street car im looking to get as close to 400 RWHP as possible
here is a vid of me parking the truck sounds kinda crappy with open headers
http://www.youtube.com/watch?v=gQq_BDPacIs
Old Jul 15, 2010 | 01:52 AM
oh yeah and pictures of the motor
Old Jul 15, 2010 | 04:24 AM
F-Body Lover's Avatar
very clean engine and engine bay but the body is not
Old Jul 16, 2010 | 06:54 PM
That motor sounds weak. A motor with a cam that sounds like that should have a snappy throttle response. My diesel truck revs faster than that. The heads are choking that motor.
Old Jul 17, 2010 | 02:14 AM
i already know the heads are not good enough flowing thats why i asked how much more power id make with vortec heads and my 292h cam and it wasnt running very good in the video the idle was too low and it was choking up i started it today and it ran a lot better ill make a new video clip tomorrow
Old Jul 17, 2010 | 11:35 AM
A ported camel hump will probably flow close to what an untouched vortec will flow. I have seen a 450 hp 383 with vortecs on it. 440-450 is your limit with vortecs on a decent smallblock.
Old Jul 21, 2010 | 10:49 PM
  #32
450 HP is enough for a street car for now at least until i get bored
Im taking my engine compartment down to bare metal then going to paint everything over again...then dropping the motor in the car
ill post pictures of my progress
Old Jul 24, 2010 | 06:53 PM
  #33
Oldsmobility85's Avatar
I have a set of 906 casted vortec heads with ferrea 2.02 1.60 valves comp hyd roller springs 950-16pn good to 575 lift 10* retainers and keepers milled to 57cc chambers and hand ported. Need 500 for the heads. have 1500 miles on them.
Also have the performer rpm airgap intake with arp polished stainless bolts both are only 3 weeks old. Need 600 for heads and intake and bolts together. Intake runners are ported and are gasket matched to heads.
Old Jul 24, 2010 | 07:34 PM
  #34
im interested in your vortec heads wont have the money for a couple of weeks though
Old Jul 24, 2010 | 07:35 PM
  #35
http://www.youtube.com/watch?v=PKV5YmLgm80
Old Jul 25, 2010 | 09:11 AM
  #36
Call me when you are ready. They are still on the car. I need to get the motor out. I am parting it out to build my 406. 813 312 2781
Old Jul 25, 2010 | 12:03 PM
  #37
Were the valve seats changed or were they just cut for the 2.02 valves?
http://www.chevyhiperformance.com/ho...458/index.html
Old Jul 25, 2010 | 04:35 PM
  #38
Old Jul 25, 2010 | 05:03 PM
  #39
Valve seats are integral in almost all vortec cylinder heads yet some where press in. Mine are integral so they were ground for 2.02 1.60 valves. Car went a 8.32 in the 1/8th but shoulda went more like 8.0 I think it was due to the fact it was 90 degrees out and my hood only clears the carb by a inch and a half or so. Its in a 96 fbody.
Old Jul 25, 2010 | 10:22 PM
  #40
I don't think it was the hood or the weather.
