Help With Head Choice
Coming along waiting for my radiator to come in the mail then i have to get a new set of spark plug wires because the other ones melted after that just put back my fender on and radiator support and hopefully start it
383 keith black flat top pistons 10.5.1 compression fuelie heads rpm air gap manifold 750 carb msd distributor 488 lift cam tci 3500 stall converter turbo 400 trans 373 gears im hoping for mid to high 12s and maybe high to low 12s with ported vortec heads onces i can afford them this is a street car going to be driven around a lot
if you have any suggestions please feel free to tell me
another question is that i went to a performance shop the other day and told them the problem im having which is that sometimes when my car gets to 200 degrees the coolant will start shooting out of my over flow tube so i went to go get a over flow tank and they had one that is sealed or one that has a filter on the top and the guy said the one with the filter on top would be better but for some reason i didnt really want to believe him so will a vented filter top over flow tank work?
i can get a picture of it to show you what it looks like if needed
Just get a basic overflow tank. No need for anything fancy.
with a 383 bottom end camel hump heads 488 lift cam not 100% sure on the duration rpm air gap intake manifold long tube headers 750 carb turbo 400 trans 3000 stall converter 373 gears what should i be running 1/4 mile i was told my motor should be making around 360-375 with the heads i have on it and if i switch to vortec heads and manifold how much more power would i make and how much better on gas would me car be?
