Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
how to identify internal balance engine?
Old Oct 18, 2010 | 07:19 AM
F-Body Lover's Avatar
Default how to identify internal balance engine?
my engine is from my Camaro z28 1992 the flexplate has weight on it but the balancer dont is there any other way that shows if the engine is internal balance or external? the engine is factory L98 TPI 1992 with iron heads
Old Oct 18, 2010 | 06:51 PM
KCS's Avatar
KCS
Moderator
Try Google. I'm pretty sure I remember seeing that the later model engines were externally balanced, but only the flywheel had weight and the dampers were all neutral balance. I think LT1's are like that too.
Old Oct 19, 2010 | 05:01 AM
now that's makes a sense thanks alot
Old Oct 19, 2010 | 06:51 AM
pancherj's Avatar
I believe the extra weight on the flywheel was put there when they went to a one piece rear main seal. I read that a long time ago, so my memory is a little fuzzy! Better read up on it for yourself.
Old Oct 27, 2010 | 08:09 AM
monster81's Avatar
it is internally balanced on the front and externally balanced at the back, just like LT1s
Old Oct 27, 2010 | 08:14 AM
jgh64pkup's Avatar
they did it with the one piece seal because its round unlike the older two piece with the counter balance
Old Oct 27, 2010 | 08:29 AM
thnx el 3edil and thank you guys
