k-member or motorplate?
There are a few out there if you look hard enough.
Good luck with your build.
Anyway to answer your question I went with the K-member swap. It made life easier. I actually wish I had less people helping me because I feel that I would have gotten further without advice from people who work on vehicles for a living. The K-member swap will allow everything to work much more easily without fabrication to other things as much. Fabrication will still be needed no matter what since it is an engine that was not suppose to go in our cars.
I have heard of some big block swaps using custom made motor mounts but that on you. K-member swap will make it stronger and lighter in the long run and more room to work in you car with.
As far as not changing your mind goes just try and think it through before you buy that motor. I think a small block would have been better in the long run if you have an endless supply of money then awesome but otherwise nothing like a rapid small block with some sort of power adder to make it perform like a big block. Your list will grow and grow and grow. If any questions, feel free to ask.
Kyle
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
bmr thanks for your post i have def spent a ton of time on your website browsing. i will be placing calls to you as soon as i have a lil more money and know in stone what i need/want. a few questions i have since you guys are "susp experts" whats the difference between the standard tubular bbc k-member and a turbo bbc k-memeber? i see its like a 100 bux dif in price so was just curious as to whats the benefit of the turbo version..........plus as a susp company what would be recommended for a street/strip car as far as motor mounting options? 1. solid motor mounting k-member or 2. motor plating using a non motor mount k-member? thats what all this is about and the main question in this entire post as i am just lost and clueless as to what benefit to a motorplate would be and wether or not i should go that route! once i know i can based off expert (people who have used both and identify the pros/cons of both) then i can really get started cause id know what damn k-member to order to start my front susp.
sorry to everyone if its trying to be explained and i just aint picking up on whats really being said lol
The pros of the motor plates are deffinately the weight and costs but the cons are rather large. First is fabrication and fitment. Second is you would also want to run a mid plate which takes a different converter. Third and most important is without a kmember you have no way of running the factory control arms. (although BMR makes a k member for motorplate cars as well which primarily is just a link for the front steering and suspension.
