New intake manifold leaks at ports
87 Monte w/ 305 4bbl...
I wasn't passing emissions because the original intake manifold had clogged EGR passages. I put on an Edelbrock 3706. I used Ultra black RTV around the front, back and water ports only. The gaskets were the papery steel core set the GM parts counter up the road provided.
I set the timing today and all is well but it's surging. I put a 5/32" rubber hose to my ear and picked up a healthy suckage over the 1/3 intake ports-to-head area. 5/7 is dead quiet there.
I didn't think the ports needed RTV, though maybe that would have masked the problem. How do I check the manifold for trueness when I pull it? I may be able to leave the stocker in my parts washer to see if I can get it unclogged and re-use it and return the Edel. to Jegs if it's bad.
Those flanges are machine finished. I wouldn't think it would be warped. check it with a straight edge of some sort but I think your probably dealing with a little debris you didn't recognize while installing.
