350 4x4 cam question
Duration Advertised 278° Intake/288° Exhaust
Duration @ .050'' 204° Intake/214° Exhaust
Lift @ Valve .420'' Intake/.442'' Exhaust
Lift @ Cam .280'' Intake/.295'' Exhaust
Lobe Separation Angle 112°
Intake Centerline 107°
Intake Timing @ .050" Open 5° ATDC
Close 29° ABDC
Exhaust Timing @ .050" Open 44° BBDC
Close 10° BTDC
I really want to go with the lunati voodoo 60100lk i think it would be a much better cam with a wider power band or even the comp cams Xtreme 4x4 X4254H cam. to keep in mind this pickup has 4.56 gears and will be turning 40" tires and will have a 700r4 when done. So i need a good low end wide power band cam, should i go with the voodoo?
Trickflow also sells one that is cheaper but will work the same I think its 210/216 its about half the money of the comp and works just as well. Its their smallest flat tappet.
Have used both to tow with either will pull well up to 5k.
