help with zz383
Dart pro 1 heads, 64cc x 215cc, 2.02/1.60, assembled with dual springs
lunati "voodoo" solid roller cam 231/237 .555/.566 110 lsa
lunati solid roller link bar lifters
lunati 1.6 roller rockers
holley 770 street avenger carb
all ARP bolts top and boottom(short block will be rebuilt/freshened up)
the car already has a vic jr 2975 single plane, holley 650(forgot the model but its definitely too small), hooker coated LT's, 3" duals with a single lateral mounted magnaflow.
so basically i need to know that i'm not mix matching parts. and/or making a newb mistake.
If it were my car id leave those heads and put better springs on em. Then pick up a GM 847 cam. all you got to do is knock the dowm pin in. will sound nasty and make 375-400 rwhp... depending on the car that good for high to mid 11's in a street car and bottom 11's to high 10's in something set up.
Also skip that street avenger and spend the money on a Holly HP or a quick fuel.
Small blocks need a 100 less hp to do what ls1's do. Just ask my buddies that call out my car lmao
and if you decide to ditch the heads and want to sell them for a deal lmk i'll take them.
My set up is far less and it will see high 11's. all motor and bottom 10's on juice
so let me ask if we WERE to go solid roller, what would be a good duration/lift to shoot for?
What gears? gonna need 4.10's or better.
The cam in that motor is tiney, I think smaller then 200 duration lol at best its a zz4 cam 208/221 duration.
ok i was looking at another lunati grind. 249/255 .585/.600 110 lsa supposed to be 2800-7200 rpm range. but it needs 10.5:1 compression and 4.10 gears(like u mentioned) however it's already pretty limited in speed with the 4 speed and 3.73's. the one thats slightly smaller is supposed to be used with 3.90's, was thinking i might try to just get away with that cam and 3.73's. that grind is 243/249 .578/.585
as far as lifters go, they aren't expensive enough to sway me one way or the other. i know hyd rollers are just as stout as solid, especially below 7k. but i'd rather do solid just for the sound and aggressivness alone.
Comps response we'll give you a new cam..... go FFFFFFF your selves. I will never use nor install a comp cam at my shop. EVER
You have a fun build idea. I like the bigger cam for sure.
and obviously we will be selling the old stuff. holley 650, vic jr, fast burn heads, and that 222/230 cam.
