Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
1999 firebird
Old Mar 10, 2012 | 07:44 AM
BIRDMAN216's Avatar
Default 1999 firebird
I bought a 99 firebird rolling chassis backin october and im just now getting around to this swap.The previous owner had it as his drag car set up for a 350/350 combo.It still has the v6 k member but he had some custom motor mounts fabbed up to accept the 350 engine and also a trans bracket for th350.There is no wiring harness either since he was running a carb.Recently i purshased a 87 & up gen 1 sbc.The cowl was already notched for the other motor. Since this guy was running a older model 350, will i have issues with the newer style block?I know the distributor sits way back against the firewall but i was wondering if the newer block has a taller distributor?
Old Mar 10, 2012 | 10:37 AM
ram88gta's Avatar
no you wont what changes is the heads, and cam so you should be good to go. good luck
Old Mar 10, 2012 | 01:01 PM
BIRDMAN216's Avatar
Old Mar 10, 2012 | 01:06 PM
BIRDMAN216's Avatar
Does anyone know what motor mounts i need? I have the uppers that are bolted to the block, I need the ones that will attach the block to the brackets I have.
Old Mar 10, 2012 | 08:26 PM
k_cash1432's Avatar
Looking at your brackets those are solid mount brackets they bolt directly to the block no mm inbetween
Old Mar 10, 2012 | 09:56 PM
BIRDMAN216's Avatar
Thanks bro I appreciate your help. I talked to the guy that I bought the car from and that is what he told me also.
Old Mar 12, 2012 | 04:49 PM
BIRDMAN216's Avatar
I want to paint my engine and motor mounts but they have rust on them. Will those rust converters work on the engine?
