My 86 Mustang coupe SBC swap.... 56K WARNING
I did a few things today after work. I got the trans out again, gunna take it and see what exactly i need to order to fix it right and make it "bulletproof"
![](http://i17.photobucket.com/albums/b99/don94/624C8434-357E-4AAB-844E-AF157EB3654B-1449-000001EF8190EF22.jpg)
The Thunderduck (1988 Thunderbird $600 beater) doin its duty.
![](http://i17.photobucket.com/albums/b99/don94/1E9ED201-CA98-4226-8CEE-C2513994C16D-1449-000001EF897538E2.jpg)
Finally got my E-Brake hooked up to the 03 Cobra brakes, I was missing that cross piece that connects the cables together.
![](http://i17.photobucket.com/albums/b99/don94/17EC8BDB-F0E6-452A-93F9-4BB5A6AA1086-1449-000001EF949D28BA.jpg)
Mounted my 2-step and Im waiting on my Nitrous retard to come back from MSD so I can wire it all up.
![](http://i17.photobucket.com/albums/b99/don94/1848827E-06DA-411A-BA76-3559B0BC6BAE-1449-000001EFA3856902.jpg)
I wanted to ask you if you are using the stock oil pan for the AJE k-member you are using?
Looks like you are using the stock oil pan but i could be wrong. Let me know.
ok awsome bro...i kept reading on different forums that the stock pan would not work...but after seeing your build i second guessed the whole thing... this is my build so far... slowly but surely...aint nothing extreme but it will get me around and good enough to have fun with til i get my 5.3 extreme build.
http://s1158.beta.photobucket.com/us...68874957684958
#34
I think I got a lot accomplished today. Tomorrow is 2 more harnesses for the relay panel and then wire up the timing retard and 2 step. re mount the NOS fuel pump, and maybe get the trans stabbed, (prolly not)
I drilled out the key cylinder of the junkyard tilt steering column and put amd key cylinder in it, and rebuilt the blinker switch. It works great now and I have tilt!!
![](http://i17.photobucket.com/albums/b99/don94/0026C431-A7F9-46CA-B1BD-85F53F295A7B-14442-00000E64DFAD6503_zps408bf243.jpg)
Made the Nitrous solenoid, purge solenoid and micro switch harness
![](http://i17.photobucket.com/albums/b99/don94/5DBF3E05-B5DE-466D-ABE6-A21E7C6FD858-14442-00000E64D913CBF4_zpsa8901d56.jpg)
This is the switches harness
![](http://i17.photobucket.com/albums/b99/don94/EEC4E981-FEB3-46B4-A64D-9196B79184B8-14442-00000E64CF34E1E1_zps6fb13c7f.jpg)
I forgot to post a pic of the headliner back when I put it in.
![](http://i17.photobucket.com/albums/b99/don94/8342D2C1-937E-4DED-B47E-956001E473A3-14442-00000E64E7544952_zpsa2dd5f15.jpg)
#35
I got the wiring mostly done. I had a little hiccup with the trans brake wiring. The way I had it before, the button was wired on the ground side of the relay and i forgot about that. The way I rewired the system the button is on the power side of the relay. So needless to say the trans brake relay didnt have any power. I ran a jumper wire to the button and everything work as it should. I just gotta run power to the TB button and everything will be good. I said **** it and came inside. Ill do it tomorrow after work. I also broke my purge button, so i have a corded button hanging out of my dash for now until i get a new button.
#40
I got the control arms on and holy **** did it make a difference!! It rides rough as **** but there is no body roll. I also installed a pinion snubber and that seems to help plant the tires. The battle box supports deal fell through so ill have to put those on at a later date. I forgot to take pics when it was in the air.
