My 86 Mustang coupe SBC swap.... 56K WARNING
#41
I drove it to the LMR meet saturday night and it did mostly good. the trans worked great, the fuel pressure regulator, not so much. It dropped to 2.5 psi on the way there, and when it cooled it rose to 10.5 psi. so now i have to get a good regulator and it is not looking good on me getting tires for tx2k13. looks like roll racing only for me FML. unless any of you would like to donate any 17" drag radials to my cause
#42
If you don't mind me askin what all is done to the motor? I'm fixin to do a SBC 350 swap into a 85 coupe when I get it to the house. Looking for low 7s all motor then add a 150 shot
#44
Ok I have not touched the car since TX2K13, due to money reasons. I came across these seats for a great price and could not pass them up. 5 minutes after i got them someone tried to buy them.
![](http://i17.photobucket.com/albums/b99/don94/C47CEA29-F48E-45BB-950A-D3E54FF0B7F7-14756-000010BC84AB5C40_zps7f369cfa.jpg)
It looks a little better doesnt it.
![](http://i17.photobucket.com/albums/b99/don94/BB0EAAA9-A321-4256-8745-E548653B3B9C-14756-000010BC8BCD1783_zpsda0ec06c.jpg)
I love these seats
![](http://i17.photobucket.com/albums/b99/don94/78A8AE74-3610-452A-9FBF-3802782B2335-14756-000010BC9B2F14ED_zps40608778.jpg)
Who wants these. come and get them.
I love these seats
![](http://i17.photobucket.com/albums/b99/don94/DAB37FC9-D865-4077-8AA7-EAB2215A879B-14756-000010BCA1C651C8_zps7e246e9e.jpg)
#49
I kept the ford starter solenoid. the only modification i did was run a little jumper wire from the big post to the "s" post on the chevy starter. I took the alternator wiring completely out and ran a 100 amp 1 wire alternator. Im running a complete MSD ignition also. mine is carburated so there isnt much wiring. the hard part of the wiring was wiring the nitrous, trans brake and timing controls.
#57
Thanks, I'm about to get started back on it again, I got some solid lowers and maybe after the next 2 paychecks I will have everything I need to get this car back on the road. I'm trying to get it ready to run in The Clash of the Titans race in San Antonio at the end of Aug.
#59
in mine there were 4 wires going to the trans through the trans tunnel on the drivers side, under the carpet. 2 were the neutral safety switch and the other 2 were the reverse lights. on my shifter there was a neutral safety switch, i still have to add the optional reverse light switch, but the wires are ran. my car was a TBI 3.8 v6 / auto car. if your car was a 5 speed it will not have a neutral safety switch it will have the clutch switch which can be used as a neutral safety switch, the reverse lights should be under the carpet where i said
