blown up 79 corvette 350... anything special?
a guy i know has a C3 with a grenaded 350. is there anything special about the corvette's engine vs the rest of the SBC's from the late 70's? i'm basically making sure he doesnt buy the wrong 350 to replace it.
Check casting numbers and do a search. You'll get all the info on crank style, block, heads, etc...if you pull a motor from another vette, camaro, or even monte/police caprice you should get RELATIVELY the same motor but not exactly similar. Remember that they were all rated differently for HP but may actually be the same motor with less of a cam, or worse manifolds as the only difference. I mean how would you feel if your 350 vette had the same rated power as an impala? hope this helped
