Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
LS1 in a Chevy Vega?
Old Aug 12, 2013 | 01:59 AM
Bow Tie Power's Avatar
Default LS1 in a Chevy Vega?
I've come to notice that the older Chevy Vegas were basically miniature Camaros. They look almost identical, but the Vegas are smaller, lighter, and use a 4 cylinder engine. I've seen several people do V8 swaps in these and I was wondering exactly what would it take to drop an LS1 into a 1971-73 Vega?
Old Aug 12, 2013 | 08:06 AM
mr.beachcomber's Avatar
Try locating a copy of the book
 "How To Swap GM LS-Series Engines Into Almost Anything" "How To Swap GM LS-Series Engines Into Almost Anything"
before you start your project. Just finding a Vega w/o rusted out frame rails is going to be the first hurdle. The next hurdle is beefing up the drive train from the transmission to the rear axle to handle the additional torque and HP. Once you've solved that problem, the front/rear suspensions are the last hurdle in the race.
Good luck with the conversion!
Old Aug 12, 2013 | 09:48 AM
cambirdracing's Avatar
I always wanted to put a 4.3/5-6 speed in a Vega. Back in the early 80's I had a 73 and 74 vega's.
Old Aug 12, 2013 | 10:48 AM
MikeFSKSpeed's Avatar
A friend of mine has recently done a SMC swap in the Vega. Not impossible; it has the Hooker Engine Mounts and Header swap but every thing in that car is TIGHT. The Hooker Engine mounts hold the front of the engine; a good way to do this with an LS may be a Competition Engineering Motor Plate Kit. They have them already fitted to the LS Engines' all you have to do is trim the plate to fit the car and weld in some brackets to bolt the motor plate to. These are readily available; I usually have them in stock
Headers would probably be one of the hurdles to over come.
Old Aug 14, 2013 | 02:53 PM
ZONES89RS's Avatar
In-Zane Moderator
Exhaust I think is the only part I would have a issue with. I don't want to make my own. My mig welder just doesn't like to get in there with my big hands for that type of work.
