SBC or LS Style?
Going with the LS1 etc will end up costing you more on set up, you will end up getting a tune for power, exhaust, wiring etc.
You are 16yo just go with the sbc & enjoy with less hassles
Now if gas mileage and reliability is a more important factor then I would go with the LS. They are definitely more efficient motors and usually never have a hard time starting. Its just that the performance parts for them are a bit more expensive than the sbc.
I have seen SBC in the high 5's in the 1/4 mile . I understand this a LS site , saying SBC are not capable is just plain ignorance.
According to everything I've seen on the internet, There are supposed to be two 5/8 18 hex cap bolts in those holes. I picked some up from the hardware store and they fit the other corner holes, but they bottom out without grabbing anything in the block on the flywheel side.
Did Chevy do something weird with their bolts in 2000? The passenger side hole goes deep into the block - dropped a long screwdriver in there no problem.
Any ideas on what size bolts I need?
Decent Camshaft/Springs: 650
Odds and ends: 150
Thousand Bucks, 400hp, great millage. If you can fabricate mounts and have access to a U pull it yard an LS build can be this cheap.
2001 Chevrolet GMC Suburban 5 3L Engine 275K | eBay[/ame]"]http://www.ebay.com/itm/2001-Chevrolet-GMC-Suburban-5-3L-Engine-OEM-275k-/360682414700?pt=Motors_Car_Truck_Parts_Accessories&hash=item53fa58e26c&vxp=mtr
