Stroke and sound of an engine
DZ302 - 4" bore x 3" stroke
327 - 4" bore x 3.25 stroke
350 - 4" bore x 3.48 stroke
383 - 4" bore x 3.76 stroke
As you can see they all have the same bore. Generally, the smaller stroke will allow more rpm. The DZ 302 with the right heads and cam will make the same hp as the 383 but at 1500rpm higher. The 383 is simply the cheapest way to get the hp at the lowest rpm.
One of the magazines recently did a modernized DZ 302 with afr 210 heads and made 519hp @ 7400 rpm. The rotating assy was nothing special.
I want to point out that while a 302 can make as much HP as a 350 or 383, it has a much lower peak TQ number and being high revving will need a really high stall converter and big gears to get moving. That said, area under the curve is less and all things being equal, the 383 motor will be way more streetable and should be faster in a race than an equivalent car with a 302.
BTW a 383 is typically a 4.030" bore and a 3.75" stroke, 377 is a 4.00 bore and 3.75" stroke.
it did not change the sound at all. It made more power though.
