sbc fuel injection swap
started a thread over in forced induction but did not really know this section was here!
wanting to boost my 327 SBC looking for ideas on doing a fuel injection swap as well, but if possible id like to get something that will be easily interchanged to an LS style system in the future, not sure what options are really i know AEM makes a trigger that replaces the dizzy, but what about intakes and ECM?
any thoughts would be appreciated, likely looking at 80# for E85 and 8-10 psi
Edelbrock makes intakes and rails. Here is a link to everything else.
http://www.eficonnection.com/eficonnection/24x.aspx
This is an LS fuel injection system on a sbc
im doing it, not for a couple months, but im deffinetly planning to do it.. im going to use the dominator efi though, just because i want something i can grow into and the features seem endless.. ill keep you posted when i start ordering parts. eventually will be swapping to a 5.3, but not really in the budget so i figure ill set this up for now, going with a victor efi intake and 80# E85 set up, will be N/A for now. not sure on throttle body just yet probably going to get an elbow to mount an ls1 style throttle body or something still trying to run my options just so everything is easy to swap later on.
it looks like i might just be doing a standard 1000 CFM square bore TB from edelbrock i guess, then ill slap my nitrous plate under that. should be more than enough to feed my 332 CU inches. interested to see how this turns out, the domintor EFI should be fun to play with.. should be worth the cost i would think. car already went 11.98 the way its set up now with no power adders and a little bit of tuning left in it on a 1.8 best 60ft. im hoping to get it down to 11.0 with a little nitrous and some better launching couldnt even foot brake without blowing my tires off
