Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Guess this horsepower
Old Dec 22, 2013 | 12:06 PM
86CAMARO400HP's Avatar
Default Guess this horsepower
1997 2-bolt vortec roller block,
xr279hr cam 495/.503 lift
218/224 I/E
vortecs modified with z28 springs for higherlift,electric water pump, hei distributor, 600 cfm crb,9:6:1 compression,shorty headers for clearance,th350 transmission, dual plane vortec manifold. All going into 86 camaro with 3:42's
Old Dec 22, 2013 | 12:32 PM
ZONES89RS's Avatar
In-Zane Moderator
It will try to make as close to 400 hp as it can. Should be just shy of it, but the torque will be greater than 400 I think.
Old Dec 23, 2013 | 01:15 PM
87silverbullet's Avatar
I don't see it making close to 400 with that small of a cam and a dual plane. Maybe 350-360 on a good day.
It took car craft to use a 230/236 cam, a 1 inch spacer, 1.6:1 rockers and 10:1 compression to make 440 hp, so to have less cam, less compression and a shorter rocker, and a dual plane intake would make it real hard to see 400 out of it.
Old Dec 23, 2013 | 01:32 PM
Paul Huryk's Avatar
I'm going to say 360 to 380, part of that also due to the cam being at around .500" lift. The 350 in my Camaro has the 219/219 Accel roller, ported L98 Vette heads, and a performer RPM and makes (according to time slips ) 395 to 402hp. I do consider the dual pattern cam a good thing in most street motors though - as long as it has enough lift.
Old Dec 23, 2013 | 05:24 PM
ZONES89RS's Avatar
In-Zane Moderator
Yep, 380ish sounds right. Like I said, close to 400. Will be fun. I has 230/230 single pattern Elgin roller that was .480 lift and on a 108 LSA, ran fantastic with the vortec heads.
