what carb to pick
355 c.i. for now although i want a crank to put me at 383.
world products steel heads that have been ported really well.
victor junior intake
540 lift roller cam
performance rocker arms and valve springs as well but i forget what they are exactly
its a street strip car and my goals are to run an 11.9 on the motor and a 9.9 on the bottle. i pretty much have everything except a carb, i did some equation thing and it said to get a 650 cfm carb but i was thinking that might be a little small. not really sure what do you guys think? also what is the best brand i heard possibly demon, thanks.
i know holleys and for the most part a fan of them, but i would recommend you consider and educate yourself on edelbrock carbs if you want a street friendly carb given your setup. you'll also want to figure your goals out and decide if you want mechanical vs vacuum secondaries on a carb if you choose a holley style carb and if you do i would not choose an oem holley but an aftermarket style holley like demon or proform which gives you more tuning capability.
here's one of many articles you can look up on the web,
http://www.rodauthority.com/tech-sto...or-your-motor/
http://www.carcraft.com/techarticles...etor_showdown/
