Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
1964-1967 283
Old Dec 30, 2014 | 10:11 AM
climberman's Avatar
Default 1964-1967 283
I bought a rebuilt 283 (3849852 stamp on engine) from a guy but he couldn't find all the exterior parts like the dipstick. There was no carburetor and so no vacuum lines. I am trying to figure out where everything goes and here is a picture for starters. I need to know what this is for.
Old Dec 30, 2014 | 10:32 AM
nofun's Avatar
Trying to remember what they call that, a "drift tube" or something like that.
It's the forerunner of the PVC valve. It should have a tube that runs under
the motor to vents the crank case. It's runs under the motor because it
would drip oil. When I had my 65 El Camino with a 283, I sealed it off
with a freeze plug and ran vented valve covers.
Hope that helps
Old Dec 30, 2014 | 10:45 AM
climberman's Avatar
Hi nofun
Do I need a freeze plug or can I just leave the rubber plug on it?
When you say vented valve covers do you mean having a cover that needs a PVC valve. and then were does the hose for the PVC valve go too.
Thanks
Rocky
Old Dec 30, 2014 | 11:12 AM
nofun's Avatar
You need to block it off sum how, the choose is up to you. Then use valve
covers with breathers.
Old Dec 30, 2014 | 11:45 AM
climberman's Avatar
I was doing more reading and found that you can put a PVC at the base of your carb and put a hose over to the "road draft tube" that is what they called it. And then you don't need vented valve covers. What do you think?
Old Dec 30, 2014 | 11:52 AM
climberman's Avatar
I wasn't saying block it off you run a hose from it to your carb and a PVC
Old Dec 30, 2014 | 01:05 PM
mr.beachcomber's Avatar
Your picture is that of a fresh air pickup for air from inside the stock air cleaner on pollution-controlled small journal SBC's. (For non-pollution-controlled vehicles, the hole was used to mount the road draft tube as mentioned above.) The PCV valve screwed into the the oil filler tube at the front of the intake manifold, and was connected by a rubber hose the carburetor's base plate. Parts are still available; however, most of them are reproduction pieces for Corvettes from vendors like Paragon Corvette Reproductions .
Old Dec 30, 2014 | 01:24 PM
climberman's Avatar
So again in the picture do I just plug that. Or should I hook up the PVC to it and the carb.
Old Dec 30, 2014 | 04:22 PM
If you intend to use the stock PCV system, this is where your rubber hose from the air cleaner plugs in to supply clean air to the internal engine. The PCV valve screws into the oil filler tube at the front of the intake manifold and goes to the carb. This diagram is for a 66-67 SBC, but should give you an idea of what goes where.
If you use a late model PCV system in the valve covers, you'll need to welch plug this hole.
While you could connect a hose to this part and insert a PCV valve to the other end of the hose with the outlet from the PCV valve to the carb, you would still need to add some source for fresh air to balance the system. (I've seen guys put a breather cap on the oil filler tube, but this solution just pukes out oil on the intake if the internal engine over-pressurizes during operation due to worn rings.) I'd stick with using either the early or late model PCV system for best results. YMMV.
Old Dec 30, 2014 | 05:29 PM
climberman's Avatar
Thank you beachcomber
Now I get it one more question though, do I need the original air cleaner or use an open air cleaner. I was reading something about that that there is a difference. In the diagram the air cleaner is a open one.
I don't want to use the late model PCV system because I don't want valve covers with a hose coming out with a PCV plug in them. I don't think that looks good
Old Dec 31, 2014 | 10:15 AM
Not quite sure what would be considered an "original" air cleaner for your 283. If you're think about using an oil bath air cleaner from the late 1950's, I would recommend against it unless you're really looking to achieve the vintage look. They're messy and don't filter enough air for any 283 engine except for the base, low performance models.
Any open element air cleaner assembly you buy today should have a provision for a clean air takeoff that you can use for your PCV system. You don't need to buy a reproduction Corvette air cleaner base unless you're looking for vintage look like the '60-'62 air cleaner assembly pictured here. (If the link doesn't work, it's essentially a covered air cleaner with louvers around the circumference. The element is foam, and since it's a reproduction, it's pricey. You can find something similar at Jeg's for less money.)
Hope this helps! Here's a picture of the '60-'62 air cleaner assembly:
Last edited by mr.beachcomber; Dec 31, 2014 at 10:23 AM. Reason: Link didn't work so I added a photo
Old Dec 31, 2014 | 01:58 PM
climberman's Avatar
beachcomber
I wasn't thinking of using an oil bath air cleaner I don't like those. I was thinking of just a stock GM air cleaner. My dad had a 64 Impala SS something like that air cleaner of course it was a 4 barrel. But I have a two barrel so I am some what limited but I am sure I will find something I like. If I hook it up like the diagrams shows you, then I can get valve covers with out holes for a PCV valve and a vent.... I think?
Old Dec 31, 2014 | 05:28 PM
...If I hook it up like the diagrams shows you, then I can get valve covers with out holes for a PCV valve and a vent.... I think?...
Absolutely. You just need a clean air inlet to the crankcase so that the PCV valve doesn't draw a vacuum when operating at part throttle. Just go to Jegs.com and search for an air cleaner assembly. You can then filter the results by your 2-barrel carb's air cleaner mounting flange diameter.
Old Dec 31, 2014 | 05:46 PM
climberman's Avatar
Thanks beachcomber
