1994 z28 Please HELP!
If the car starts with starting fluid, it's a fuel issue. I'd verify the injectors are actually firing. Pull both rails and watch them as someone else cranks the car over.
94 and 95 F-bodies are OBD1, but will not flash with the jumper on the port. You need a scanning program. You have the 12 pin ALDL port, so you'll need a USB to OBD1 12 pin ALDL cable ($60 or less, or you can make one your self for less than $10 if your savvy in that kind of stuff). Then get your laptop and download Scan9495.exe (Google it, it's free!). Connect your laptop to your car and enjoy.
That program can do more than pull codes as it's a full data logger and you can access ABS and other PCM and BCM functions and manually switch them too (great for bleeding the ABS module). Once you have all that, you're Tuner Pro RT (free too) and WinFlash ($20) from tuning everything on your car your self (gears, tires, exhaust, cam, heads, tb, everything). Not many cars out there can do that for under $100. Most can barely get a code reader for that price.
Too many times people toss prefectly good optis (usually Delco or Delphi) when all that is needed is a cap and rotor (much cheaper). They end up replacing the opti with a cheapo unit (anything not Delco or Delphi), then the opti breaks "again" in 6 months or so, and it's the optis fault......
People, if you have fuel OR spark, it's not the Opti. Proper troubleshooting can save you time and money.
