Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
bbc 482
Old Oct 14, 2015 | 09:26 PM
onebadblazer92's Avatar
Default bbc 482
I have a bbc 454 bored 100 over in a 92 k5 blazer 4wd lifted 6 inches on 35's stock 373 reciantly replaced the pinion and ring rebuilt 700r transmission and new stock converter ovel port heads and comp cam i dont know the size of the cam off the top of my head but has good bit a lope hei distributer keith black pistons and cast crank cast stock intake with 3 inch spacer and a 650 edelbrock 4 barrel carb me and my dad built it and recently started it up and it acted like it didnt have much power and seemed like a turd lol is there any way to boost horsepower witb out replacing heads and putting more compression in the motor
Old Oct 19, 2015 | 04:06 PM
Onlyhavechevy's Avatar
Do you know what compression youre running? Is this the original transmission that came with the car? 650 sounds a little small for the size of engine you have.
Old Oct 20, 2015 | 08:25 AM
pancherj's Avatar
I built a 496 for my friends 1971 Monte. It has stock oval ports (049). The combustion chambers were huge (121cc). I milled them as far as we could go (110cc) and purchased some small dome pistons. That gave us just shy of 12:1 compression. It has a Comp XE 274 camshaft. It has some decent guts, loves an 850 double pumper, needs a good bit of timing (initial and total). If you are low on compression, small carb, not enough timing, etc...I can believe it is a turd. especially with those big tires, 3.73 gears and a stock converter!
