Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
427 SBC Torque Monster
Old Mar 4, 2018 | 10:51 AM
CNC BLOCKS N/E's Avatar
Default 427 SBC Torque Monster
Spent some time on the dyno yesterday on a SBC 427 build for a good friend of mine. He wanted a SBC with BBC torque down low for his street build. This engine laid out some impressive numbers.
Was a very efficient engine only required 32 degrees of timing it did not like 34 degrees and it did not like 30 degrees.
This is what I came out with and it was no budget build LOL.
This is also on my F/B page with a lot of pics of the build
Facebook Post
This will be the only one of these I will build I can take it off my bucket list as I have wanted to this build for a long time and it came out as planned.
Dart SHP block 3.875 stroke X 4.185 bore sonic tested 3 blocks and this one was the best one
Callies Comstar crank
Scat I beam rods 6.0
Custom Wiseco dished pistons.
Ultradyne HYD roller on a GM step nose core I used the GM spider and GM roller lifters reduced the base circle to 1.050 Lifters were quiet block need no oiling modification LOL
AFR 210 heads 75 CC chambers
Eddy Air Gap intake
750 Quick fuel carb, Wanted to go to a bigger High speed air bleed but the customer said leave it alone it was fine.
Scorpion 1.5 rockers
Champ 8 quart pan
10552 Oil pump
Old Mar 6, 2018 | 12:10 PM
ZEN357's Avatar
Very Impressive Build!!!
