406 400sbc build (pics soon)
My own personal build but still using alot of the parts we offer in our complete rebuild kits.
Digging through one of the shops on the family farm, i found a few engines. Most were just run of the mill 350s so i sold those to some derby guys cheap. Then i found an odd short block. It was locked up, probably from sitting, but measured out to a 400 bore size. So i figured, what the hell. I already have wayyy too much on my plate anyway so why not make this a build also. This one will go a bit slower as its going to be a bit more expensive than just buying a jy ls and machining it. So the build is as follows.
2 bolt main 400 sbc
Parts i will reuse
Block
Crank
Thats it lol. Pistons are completely smurfed so no saving them. Rods...if you need em ill sell em cheap.
Now onto the fun stuff!!
Goal: 500hp at the crank
New parts
Bottom end
KB 4.125 flat top pistons
Std fit moly rings
5.700 forged floating pin rod arp pro2000 bolts
Sfi 400 balancer
Sfi 400 flexplate
King rod and main bearings
Durabond P series cam bearings
235/243 roller cam with retro tie bar rollers (block not machined for spider or thrust plate
Roller cam button
Dual row full roller timing set
Windage tray
Oil pump im somewhat torn on. I want a very high quality so i may spring for the melling shark tooth std volume high pressure pump with bolt on pickup tube. That seems to be top on my list. Input?
Block will be 0 decked with arp main studs
Top end
Vortec heads modified for 400 block
Machined for .600 lift
Screw in studs
1.6 roller rockers self aligning
Hd pushrods
.600 lift dual springs with ti retainers
LEADFOOT 2.02/1.6 sbc valves
Slight port work
Induction/efi control
Edelbrock pro flo xt manifold with tb
Efi connection 24x kit with billet front cover
Weiand 6000fwnd cast alum finned oil pan
Holley classic black finned alum covers with Holley logo
That really covers everything. I COULD get some more expensive alum heads of course or what have you but the vortecs will fit my needs. I wanted some L98 heads but dayum since GM stopped making them they went to the moon on price. Ill still be in to it for a good amount esp on the efi connection kit, but not too bad. I have nothing to put it in, so its really just a fun build to sell later pretty much.
Any input or comments?
Ill have pics soon, but its going to be a slow process. The short block is still together...stuck lol
2 bolt main 400 sbc
Parts i will reuse
Block
Crank
New parts
Bottom end
Std fit moly rings
Sfi 400 balancer
Sfi 400 flexplate
Roller cam button
Windage tray
Top end
Screw in studs
Hd pushrods
Slight port work
Slightly more compression and a solid roller, went mid 8's on a 250 shot in my track Luv truck with a set of track 1's. I like the pump you specc'ed, I have one in my street Luv...
It was only made for 10 yrs. And its the red headed step child really of the sbc world. most dont like them because of the siamese cyls etc etc etc. They blow them up from using wrong gaskets, wrong heads and other ways.
How many more LS engines does the world need? Its my own project, but a fun one.
Its different in that its getting a roller cam and the efi connection kit. Plus im building it exactly how I want. Fully tunable with the EFI Connection kit.
Itll be fun eye candy if nothing else.
Im really into keeping it as budget as i can with the heads. The vortec are a nice setup and its not a hugh rpm build anyway so maybe just putting in the bigger valves with the large bore and a proflo intake will be enough. based off so many other builds itll be in the 500ish hp range which is more than enough for an efi sbc imo.
Right. Pics i may have some this weekend. The weather has been terrible here.
I dont have any plans actually. I may just put it on a test stand for the moment. If it generates enough interest (and dollar signs) id sell it and likely make an entire kit to build up others similar.
406 is a great engine, had one in my 82 Z28....lots of torque. Only issue I had was keeping it cool. I put a bigger rad in it and it helped, but I was young then and didn’t have a lot of cash. A big rad and fans is a must. I’ll keep my eye on this build, sounds like it’s gonna rock!
There are a few magazine builds that did it already.
Im kinda following in their footsteps for the most part. I dont have an engine dyno so that wont be possible though.
While i dont like magazine builds much, here is one
https://www.hotrod.com/articles/ccrp...l-block-chevy/
Its in the 466 or so range, but mine will be with a pro flo xt, eficonnection 24x kit, and roller cam with some likely 1.5 roller rockers.
So a jump up on some things.
Id prob ditch the stock crank for a cast scat for internal balance, 5.7 or 6.000 forged rods, and some keith black pistons. Ill be looking at 0 deck also and then add in some better valves 2.02/1.6 swirl polish style.
The dyno there was with all stock vortec heads also.
I may throw a few more tricks at it, but itll be a budget-ish build with durability in mind but also efi goodness and loads of tq.
235/243 .530/.565 110lsa
So its gonna chop chop. The larger chamber of the 406 will help the valves too im sure, but we will see.
I dont expect alot, but 500 would be nice. maybe i can find an engine dyno to hook it up to and run it.
Its a personal project for me so itll take a little time, but its not going to be too crazy. Maybe more...eclectic.
I wanted some new l98 heads but they are vaporwear now so ill settle for new vortecs that are machined for what i want ie .600 lift and screw in studs and the larger valves
