5.7 from 2000 Escalade
Would this have the same heads as the late 90's truck engines that are supposed to be very good small block heads?
Should be a roller valve train also I'm thinking.
Be mindful of the stock press in rocker studs. If not pinning or replacing with screw in studs stay under .480" lift on your cam selection. You can go bigger with some modification to the stock castings.
