Gen 1
A .030 over block with the 3" stroke crank could use 1.56" compression height generic 305 pistons if you used the 5.94" rods. Vortec block is roller cam equipped and those 305 Vortec heads are the best flowing small chamber Gen1 small block heads you can find. I could see a ~270 cubic inch engine making power to 6,000-6,500 rpm with a small cam. Probably get 300-320 hp out of ot. Zero deck the block and get as much compression as you can. Put like a 390 cfm 4bbl Holley on it on a dual plane manifold.
