Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Lt1 swap
Old May 26, 2019 | 05:43 PM
Vonholt53's Avatar
Default Lt1 swap
I'm in the process of putting a lt1 in a 95 chevy k1500 truck and plan on intake and a holley sniper efi and rear distributer I'd like to know ahead of time if there mite be any issues i mite be facing doing this any advice would be appreciated.
Old May 26, 2019 | 08:01 PM
B52bombardier1's Avatar
I'd definitely replace or service the Optispark system now. It was a known weak spot in LT1 engines.
Rick
Old May 28, 2019 | 08:48 AM
biketopia's Avatar
Rick
You missed the part where he said he's putting a traditional intake and distributor in it.
OP you'll be good to go, what trans are you using?
Old May 28, 2019 | 08:55 AM
Vonholt53's Avatar
I'll be using the factory 5 speed in truck which I'm not sure what is I'll find out though
Old May 28, 2019 | 09:40 AM
biketopia's Avatar
All good since you're using the holly set up you won't need any info from the trans so you'll be good to rock and roll.
Old May 30, 2019 | 11:17 AM
hokeplaya05's Avatar
should be an nv3500 unless someone swapped an nv4500 in it
