Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
L29 help!
Old Jan 31, 2021 | 06:31 PM
Jwilliams41's Avatar
Default L29 help!
I hope I’m in the right spot. I picked up a L29 with transmission for really cheap. Anybody know if I can get a stand alone ECM and harness for said engine? Anybody tried to build power with these? If so how was it? Thanks in advance.
Old Feb 4, 2021 | 09:52 AM
yevgenievich's Avatar
411 ecu will work with 02 van program for 4x crank and 1x cam signals. I am in process of trying to change to a 488 block and trying to find 24x 1x timing set to trade for 58x and 4x timing set that I have.
Old Feb 4, 2021 | 03:54 PM
dirtybob's Avatar
From what I've seen the heads on those won't support many rpm...peanut port heads are a better choice
Old Feb 4, 2021 | 08:34 PM
Can you run the old school heads, like the mark iv heads? I have a set of peanut ports off of a 77.
Old Feb 4, 2021 | 08:35 PM
What software can I use? I’m looking for ecu and software where I can tune myself.
Old Feb 5, 2021 | 07:46 AM
dirtybob's Avatar
Maybe...
https://www.yellowbullet.com/threads...-block.469603/
https://www.speed-talk.com/forum/vie...hp?f=1&t=59845
also need to consider chamber size (lost compression). sounds like a can of worms unless you're planning to overhaul the motor or have a decent set of <100 cc chamber heads sitting around.
