Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
tuning a holley 4150
Old Jan 15, 2005 | 05:24 PM
SSPerformance's Avatar
Default tuning a holley 4150
Ok heres my problem....if it just mash the pedal it like chokes it self kinda like stumbles then takes off....should i buy the accelle pump cams and mess around with them or try something else first?
Old Jan 15, 2005 | 07:44 PM
CTSV05's Avatar
Normally, I start with the squirter, if you have any kind of motor the factory sq. are too small.
On my 421 we had 42s.
Usually the cams will not need tuning, unless you feel they react too slow, but it normally will be fixed with the sq.
Old Jan 15, 2005 | 08:48 PM
mzoomora's Avatar
14 Second Truck Club
They are usually like a 29 or 31 or comething when they are stock, waaayyy to small most of the time.
Old Jan 15, 2005 | 08:49 PM
im also runing a MSD billet mechanicl distrubeter....when timing it is there anything specail like an advance to unhook
Old Jan 15, 2005 | 11:46 PM
CTSV05's Avatar
Shouldn't be, you always want to set the total timing and let the initial fall where it may.
Total is usually checked above 3000 rpm.
Old Jan 16, 2005 | 01:04 AM
kp's Avatar
kp
your stumble could be from not enough timing or lean carb jetting also. Unless you have the bigger 50cc accelerator pumps dont go too crazy with the squirter size. Unless its a pretty radical setup 31-35s should do OK if everything else is right on a street car.
Old Jan 16, 2005 | 07:59 AM
Ls1LikeNoOther's Avatar
Total timing should be set at whatever RPM you want to have all your timing in it, 3000 RPM is usually a good RPM to set at with a bbc. If it has a stumble when you mash it the secondaries could be not opening right away,or too soon.I would check your timing make sure you got it where you want it then start messing with jets and squirters.
Old Jan 16, 2005 | 08:00 AM
When you set the timing if you have a vacuum advance on the Dist, you always want to disconnect that from the carb.
Old Jan 16, 2005 | 09:47 AM
like i said in the oringal post its mechanicl advance...
thanks guys i will doublt check the timing
