Center Squirt Carbs
I'm curious, does anybody have any experience with 660 Holley (center squirt, annular booster) carbs on tunnel rams? We're looking at putting a pair on dad's '69 Camaro (427, big ports, 2.30" I, not sure of exhaust, 12.5:1 compression - closed chamber, .747"/.737" lift and 289*/279* duration @ .050" lift solid roller cam, wound to 8,000 RPM). Who thinks what?
the center squirt holleys (4224) work OK but unless you have the metering block kits with the changable rear jets they are fairly useless on a race car, plus the single feed makes changing jets even a bigger pain. I used them on a lot of cars over the years but with that size cam you have I would use a good late model intake with a pair annular discharge 4 corner idle 750-850s.
I have ran a pair of 1050s on setups less radical then what you have there with good results - on a race car. Two 660s on a tunnel ram doesnt = a 1320 on a single carb intake, you can pretty much run two of the same size carbs you can run on a single 4bbl intake. A GOOD tunnel ram is always worth power over a single 4bbl - just is a hassle with linkage, fuel lines, idle and paying double for carbs etc
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
