Nascar style SBC or Supercharged BBC?
Originally Posted by Fandango
I kinda figured that the SBC's were for the roundy-round stuff, but had wondered about a max effort SBC.
Thanks for the opinions guys.
Originally Posted by 8KickassRS9
what bout a hardcore sbc454?
I agree w/Fandango a standard 23* head is a restriction on a large cu. in. sm. blk.
This is why I'm switching to an 18* head. My AFR220s are an excellent head, I think on a 383 or 406 they would rock, but since I have such a high quality bottom end, I can't justify a new motor right now. I have a 421, I love the torque of the smaller head, it has great throttle response, and this motor has been driven on the street with no problems.
So I guess as always, the question is what are your goals...budget...and intentions for your combo?
I say go bbc. The extra cubes will make it easier to reach the power levels you want and tame it down a little....depending on how you build it. A blown bbc would make plenty of power.
And if you follow the article you posted try a 502 or 509.....should make it interesting.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I was going to go with a 489. The 454 I have is a cast crank standard fare 1973 model.
I figure that a 9:1 compression ratio will be enough for me on 7psi. Heck, maybe even throw on an intercooler to crest 1000hp. Maybe even a small 50 shot.
I'd also go with a splayed 4 bolt main conversion. 4.25" crank, 4.28" pistons, 6.385" rod. The one thing I have been debating though is aluminum rods or steel rods. Aluminum rods would help offset the extra rotating mass of the 4.25" crank. But I'm not sure that they would clear the pan rails on that much of a stroke.
yada yada yada. It's all talk until I pony up the money and do something.
If you're gonna drive it on the street at all you should go with steel rods even if they are heavier. One of the threads a while back on whipplechargers showed a dual 2.1 liter setup good for 880 hp at the crank, and you can't beat that whining sound....
Why no aluminum rods on the street?
I'm sure the load on the engine would be less on the street.
Is it time of engine operation a consideration?
Originally Posted by AdioSS
aluminum rods stretch and break a LOT sooner than steel rods. Steel rods will almost last forever. A competitive drag racer will need to change alum rods every season minimum.
remember that rods are subjected to compression and stretching(can't remember the proper term) and stretching is where aluminum shows its weakness. Real street cars should run steel rods almost every time(ls7 comes to mind as an exception).
Just my 2 cents.
#32
Originally Posted by pwr2w8
yep.
Just my 2 cents.
Just my 2 cents.
Might have to step it up to a little more power and go with that 489 to get those 150mph traps.
#33
Racers generally count the runs on an aluminum rodded motor for their life expectancy, on a street motor you lose track and may run them too long and that could be ugly.
#34
My old man had a black flamed 57 chevy with an aluminum 434 SB2 headed motor and a 5 speed. He ran 9.0's @ 153 @ about 3200 lbs on 10" slicks. It made apx 950 hp with 2 carbs and 900 hp with 1 carb. (made 860 hp on Patterson's dyno with 1 carb, belt water pump, less compression, less port work and 7 ci smaller.) Used to smoke a lot of big blocks with NOS and powerglides. He alway liked when people would ask him how much nitrous he was spraying and he would tell them none. Its for sale with the transmission if your interested. It had a different sound than anything else you would here at the track, it flat screamed.
Stan Williams
stan@williamsservice.com
Stan Williams
#35
Originally Posted by LOnSLO
Single dominator w/ 540 inches making 1120 hp? If that's true, that's incredible.
http://www.steveschmidtracing.com/ssr_066.htm
Do you need custom pistons for a big cube sb2.2? Could a person use the stock short block with dished pistons? I know it would need a different cam, headers, and intake valvecovers.
#36
You have to decide on an end goal and do it. How quick do I need to be..How much power do I need to get there...Can I do it with my chassis...How bad do I want this? Since I have a post going concerning an SB2 Vs. LS1 I am going to sound a little off here; but I would go with the BBC over the SB2 if you don't have access to good used Cup parts. I am not knocking the SB2, as they are very bad; but unless you get some stroke in them they are going to want to wind to the moon. If you cam them for low RPM with Cup cubes you are waisting their potential. I know that the late Mr. Lingenfelter had some experience with these heads in both high and low r.p.m. applications way back to the pre .2 versions. He had a SB2 dragster that he was running in an NHRA altered class before the pro stock truck thing. At one race at Gateway he had a lifter bar failure and knocked the socks off of one of my buddies (Same Class) when he simply stuck in a new pair of lifters and popped the intake back on with the missing chunks of lifter who knows where. After the incedent my buddy went back to finish putting their car together and I stayed behind to talk to John. His comment to me was that it really gets my buddies goat when they have to spend all of there between rounds time grinding clutches and messing with tunning their big chief headed BBC just to get beat by a econo type dragster with a S.B.C. and a powerglide. He woulf rather spend his between round time drinking rootbeer and relaxing which is exactly what was done following the incedent. B.T.W. he won that event putting my buddies team in second place. That followed through the whole Pro-Stock truck thing even though they then ran as teammates; but that was with 12°'s or non SB2 splayed valve heads. In any event I would still go with the BBC for your basic no cube drag classes especially if you have a heavy car. The CC engine is cool; but I have seen enough 502's and H.O. 454's with the dammaged cylinder walls due to ring butting that I would chose to build my own. If you are an engine guy a crate just doesn't rate; but they must make it nice if you are trying to make a publishing date. FastTimes motorworks had an engine build published in an older PHR that was built around a procharged 502 pump gas engine. You might want to check this out if you don't have any of the parts bought yet. It was what every 502 dreams of being when it grows up. If all you are looking for is r.p.m. then just snip those little loops of wire on the back of your tach.
#37
Thats the thing. I have a seasoned 2 bolt main '73 454 just sitting at home, with no use for it, or any car for that matter. It's nothing special, just a cast crank, cast piston affair. I have heard that the stock cranks are good for about 600hp, and the oil system is just about bulletproof. Thats why I had the interest in the BBC.
On the other hand, nothing quite sounds like a SBC shreiking down the track ,while grabbing gears. In all honesty I think the SB2 thing is a dream, but would be cool to do, and make it consistently quick, like Lingenfelter's setup you mentioned.
Forged blower pistons are cheap and easy to find for BBC engines, so that is a plus. The same thing goes for the rotating assembly. The same crank they used in that CarCraft article is about ~450 from SDPC, from what I remember. Also, using stock style forged rods would keep the cost down as well. But then the blower adds up, andI'd like to use an intercooler of some kind. Be it a small shot of nitrous, liquid to air, or air to air.
I think I just talked myself into the BBC.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#38
My old man can make your SB2 dream a reality if your interested. Give him a call he wants to sell one. 434 ci 950 hp n/a screamer. Ask for Rodney Williams 620-878-4225 from 8-5:30 central time. thanks Stan Williams
#39
i have experience with both...first the sbc at 393 ci and sb2 heads...the sb2 is an exotic head which requires more work to do regular maintenance like torqueing the heads, they cost more to get set up and require sb2 specific valvetrain(make sure the set you buy has the rockers), pistons, headers, & more...there are several different versions of sb2 with slight differences just enough to get in your wallet...it loves 7000 rpm +...to optimize the power you need a 5sp like a liberty with clutch...for all that expense i only gained 100 or so horsepower..they are cool tho, and people gawk their eyeballs out....then i changed to splayed valve chevy heads and they were much nicer at the drag strip but just as much a pain in the *** to maintain & set up....now for my all-time favorite....BBC...you cant go wrong...you can even build one with used parts with 15yr old technology and make 1000 hp...if i had to chose, go BBC, blown or nitrous, its the way to go
