Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
need help roller rockers!!!!!
Old Feb 24, 2005 | 10:50 PM
biggreek33's Avatar
Default need help roller rockers!!!!!
every time i start my 94 ta with 1/6 roller rockers installed in them by the way. they just tick on acceleration even when driving for a while and car is warmed up.any suggestions would be grreatly appreciated... thanks in advance for any help..... 94lt1 m6 ws6 conversion to a 97...
Old Feb 24, 2005 | 11:07 PM
CTSV05's Avatar
Well, not an expert on these motors, but do you have the self aligning rocker arms?
How are you adjusting them?
Normal procedure for hyd lifter, as I said no expert on the LT1, is to zero lash then another 1/2 - 3/4 turn.
Old Feb 24, 2005 | 11:23 PM
biggreek33's Avatar
i believe they are self adjusting,but will check on it from friend who sold it to me..
Old Feb 25, 2005 | 06:41 AM
CTSV05's Avatar
Maybe you misread, I asked if they are self-aligning?
There are no self adjusting rockers.
Old Feb 25, 2005 | 08:28 PM
mzoomora's Avatar
14 Second Truck Club
Possible spark knock? If the rockers were loose they would tick all the time usually. Try some better fuel or less timing. Also, try adjusting the rockers cold. 1/2 turn past zero lash. Do you have upgraded springs with stock lifters? Spring pressure could be collapsing them.
Old Feb 26, 2005 | 05:23 PM
biggreek33's Avatar
i will check on the self aligning part will get back to you on that.
Old Feb 26, 2005 | 09:37 PM
Muffracing's Avatar
You could try setting them with the engine running. When they stop making nise they are tight.
