Little Help With My Project
Looking at using a 90-93 S10 and dropping a 350 backed by a 700R4 trans, using the 700R4 as I need an overdrive do to the long drive to school and the fact it'll be a daily driver.
Now, I'm looking to run a carb'd engine so I'm thinking about grabbing the parts from an older full size truck/SUV, any certain year better then another? I'll basically be pirating the engine, trans, wiring, accessories, etc from the truck.
Then all I need is the mounts, rad and electric fans. Now with Headers do I need the swap headers or can I just use some nice long tubes?
Last question is do I need an ECM controller or non-ECM controlled transmission?
Also, for anyone who's done the swap, any tips/pointers/info you can give me would be great.
I want to try and keep it all under $5000 total including the truck plus maybe a few goodies if there's cash left over.
For headers you need the swap headers. The long tubes are no good for a daily driver. They have a tube on each side that run in the wheel well, limits your turning radius.
I am using a 4.3 S10 radiator with dual 12" fans, works fine. You can also use a mid-late 80's corvette radiator and mid-late 90's Taurus 3.8 fan.
For the trans you should go with non-computer controlled. All you need then is to wire the lock-up converter. I have mine wired to lock-up automatically in 4th gear.
A good tip would be to start with a 4.3 truck. You can reuse the trans(will need to be strengthened), the radiator, driveshaft, accesories(alt, water pump, p/s, etc). If you wanted to go with a TBI it would be reliable and very easy to swap. You could reuse all the sensors and the throttle body itself, the wiring is the same, just have a chip burned. Just upgrade the throttle body later on after you get the thing runiing. I had a 454 throttle body on mine with edelbrock tbi intake, trick flow heads and a comp 08-305-8 roller cam. It ran 13's regularly(traction limited), and it was my daily driver.
I was looking at the V6 truck but I didn't know you could use so much from it.
Does it use the 700R4 trans? What needs to be beefed up in it?
Thanks for all the info.
Also, many of the S10 700R4's have fewer clutches in their clutch packs, which lessens their strength. It will hold in a mild V8 application though. I used the NV3500, which is the 5 speed that comes behind the 4.3. It held up great. I ran a Ram HD 12" clutch, and detroyed the clutch at the track, no harm to the trans.
I'm guessing the full size trans has more clutches in the clutch packs right?
I'm I do use the s10 trans, what should be built up? Guessing new clutch packs, Stronger Sun Shell and a new, higher stall converter.
One of the guys here at work has a 89 S-10 with a small block. I know he used van acc. brackets and a van TBI computer with the stock 4.3 harness and just lengthened a few wires, he changed the cam a few monthes ago so know it has a Holley carb on it, he also used the stock in-tank TBI fuel pump with a Holley regulator.
Still need the TV cable with a BG carb?
Also the TBI engine was metioned, was that the engine that came in the late 80s/earily 90s Camaros before the LT1? If it's gonna be an easier swap I may go that route.
How easy would it be to use the TBI or TPI engines?
If I do go 5spd (or rather 6spd in this case), I'm guessing the T56 can take a lot of abuse?
