What pushrods to use? lenght, width etc...
I would recommend the crane chrome moly heat treated pushrods....stock length....part number from Jegs is 270-11621-16...95.99 for the set. These will last you for a long long time.
Hope this helps..Mike
Brand: Competition Cams
Product Line: Competition Cams Nostalgia Plus Camshafts
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,800-6,200 RPM
Intake Duration 050 inch Lift: 229
Exhaust Duration 050 inch Lift: 236
Duration at 050 inch Lift: 229 int./236 exh.
Advertised Intake Duration: 276
Advertised Exhaust Duration: 283
Advertised Duration: 276 int./283 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.468
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.462
Valve Lift with Factory Rocker Arm Ratio: 0.468 int./0.462 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash (in): 0.000
Exhaust Valve Lash (in): 0.000
Computer Controlled: No
Grind Number: CS NOSTALGIA L79+
