What cam for BB489?
454 BBC (4.25 stroke, 4.28 bore= 489 ci)
ported 049 heads (2.19/1.88 valves)
9.5-10.1 compression
RPM air gap manifold
850 mighty demon carb
2700 lb camaro 1968 (without engine)
th 350 (may change to th 400 if needed)
2800 stall
3.73 eaton posi
full length headers with 2 inch primaries
So far I've called crane and comp and got two different recs. The more info I read, the more confused I get!! This will mainly be a street bruiser with occasional street time. I'm looking for a torque monster that runs tough and sounds tough! Comp rec. the 288 XR 236/242 at .050 inch .521/.540 and crane offered the same duration with .610/.632 lift. What do you think of these two or is there a better option for my application? What will be the best duration/lift combo for this application? Thanks guys.
Duration and lobe center determine manners, so you want to open the valves as much as possible on a low duration cam.
I am now running the XE294HR and running mid 7.70s@91mph w/ a 3200stall. It'll rev up to 6200rpm, but power falls quickly after 5800rpm.
Both cams are very streetable.
How does that 294 idle?.. Does it sound good, lopey? I thought about getting that one for my 489. I don't plan on reving past 6000 though.
I run a solid roller, 244 @ 050, duration, and .644 lift.
Shift it at 5800 and street drive no probs, sounds sweet.
454 bbc, 3500#'s 11.40's pump gas......same heads, 950 carb, 9.6:1 comp, single plane intake. 3000 stall, and 2" headers.
I'd expect somewhere in that range if you go roller and mid-high 11's in that car if you hook up
502"
10.2:1 compression
GMPP 290cc oval aluminum heads (105cc)
Comp XE294HR
Accel Single Plane intake
1000cfm TB
FAST ecu
2" headers w/ 3" dual exhuast, X pipe
I made 490rwhp@5800rpm and 622ft/lbs@3300rpm.
Here is a video of the XE294HR w/ open headers.
Here is a video of me at the track w/ full exhaust.
502"
10.2:1 compression
Comp XE294HR
1000cfm TB
FAST ecu
Yes, it's the 294. I am running a 1000cfm throttle body w/ fuel injection, no carbs here. I can idle at 650rpm all day long. I have a 3200 stall so I don't see any torque numbers below that.
502"
10.2:1 compression
Comp XE294HR
1000cfm TB
FAST ecu
I'm kidding, I'm kidding........I'm obligated to harass BB guys!!!!!
Also I do not run a huge pressure solid roller spring, it is a hyraulic roller spring, which will do just fine unless you plan on spinning it 6500 plus.
I have run mine to 6500 but will not ET any less than if I shift it @ 5800, so why spin it. Any questions let me know. I will try to help you out. Or email @ blue66@highstream.net
heres what im im doing
-489 ci
-longer 6.375 rods
-around 10.5:1 compression
-fully ported 781 heads with Manley severe duty 2.19 1.88 valves using smaller 11/32 stems dont have any flow number yet cause there not done we are expecting around 320 cfm wich should be a piece of cake.
-comp xr288 soild roller street cam 248*/254* duration with 653"/660" lift using edure-x lifters
-roller rockers, might with Jesel sportsman shaft rocker system
-Vic Jr oval port intake
-Mighty Demon 850 carb.
im hoping for 11's this is going into a 4300lbs truck
As for the cam lift, I would say go with the higher lift, bacause if the car won't see that many street miles then I don't think you should be too concerned with valvetrain wear. Besides, for a bb .600 isn't THAT much lift so go for it.
