Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
procharger
Old Mar 27, 2005 | 05:42 PM
redbandit98's Avatar
Default procharger
hey...im debating on whether i want to go forced induction or nitrous on my sbc project for my 94..i was wondering if any of you have sucessfully put a centrifical charger such as a procharger or a vortech style along with a carb or aftermarket efi such as the accel dfi setup on their fourth gen? ive got a 94 and i was wanting to probably go with an accel dfi setup or maybee a dominator carb setup with a supercharger..Problem is i have saw many cars with the sbc setup and all of them have their cowls clearanced for just the carb itself..i know they are using a high rise single plane intake in this case but would it be possible to put a slightly lower intake on it along with the carb or dfi and still have room enough for the charger intake...this is what i was looking at somehting like this right here..... i also have considered going with the holley stealth ram setup with the nitrous, but didnt know how much work it would be to plumb the intake for direct port...
http://www.procharger.com/chevy_f2.shtml
Old Mar 27, 2005 | 07:20 PM
PRAY HRD's Avatar
i'm workin on the FI setup! but it's going to be a while yet. hopefully before summer is over if not sooner.
Dave
Old Mar 27, 2005 | 07:26 PM
matt346ls1's Avatar
If you are interested I have both a Procharger and a Vortech brand newavailable if you want a smoking deal.
Matt
Old Mar 27, 2005 | 08:24 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Matt
PM me on what the "deal" is. That is if he doesn't want them.
Old Mar 28, 2005 | 07:11 AM
any of you guys think a holley stealth ram would fit? in the back of my mind..there is a little devil as well that as been tempting to build a HIGH compression race gas NA motor as well...no bottle filling...no probs with hood clearance with top mount stuff (carb,accel dfi tb w/supercharger) if the unit would fit ...hmmmmm
Old Mar 28, 2005 | 09:37 PM
72chevy2's Avatar
^^^ why not build a forced induction motor to run on pump gas and make the same if not more power then the n/a motor? no need for high $$ race gas and still be able to ride anywhere you want?
Old Mar 28, 2005 | 10:49 PM
well it would be so i could run in the no power adder class...i dont really care though i want a fi motor... and i really want fuel injection as well but i dont know what the heck will fit and what wont without cutting the windshield which i will not do.
matt
Old Mar 28, 2005 | 10:55 PM
ta12sec's Avatar
I have a full setup for a carbed small block msd box disy btm ect fuel system and d1 charger pm me if intrested cheap cheap cheap
Old Mar 29, 2005 | 09:22 AM
slow trap's Avatar
i have the holley commander 950 system with the regular intake,not the stealth ram,but with that system you would have much more clearance,especially with a hat on top for the supercharger.
Old Mar 29, 2005 | 07:16 PM
hows that 950 working for you and is it pretty tunable as far as what you can do ....
Old Apr 2, 2005 | 03:05 PM
slow trap's Avatar
i had a hard time tuning it because of a big cam but very tuneable. i believe the brain is the same as the stealth ram,just the intakes are different.you can set anything you want=wot timing at any rpm,part throttle,cooling fans on/0ff at certain temps,set idle rpm,pretty much anything.i'm using a carburetor right now because of my bigger cam=259/267* @ .050 ground 106/102 so tuning would be a bear.good luck.
Old Apr 21, 2005 | 07:19 PM
thebowtieislife's Avatar
i run a carb set up with an f2 procharger on a sb 355, makes over 1000 hp and 24psi of boost. the tuning is pretty simple. i use a carb shop blow through 950. and i drive on the street with no problems. you try to make that kind of power going n/a say goodbye to driving on the street
Old Apr 21, 2005 | 08:36 PM
dam..your the man...i would like to get a pic of that if possible so i can have wood for 3 days...
Old Apr 28, 2005 | 08:33 AM
68birdls1's Avatar
just get a roots style blower and call it a day. might cost more, but it is definatly worth it!
Old Apr 28, 2005 | 06:29 PM
haha i would love to but there is really no room for one unless you cut the windshield..hell there isnt barely enough room for the carb alone..haha i ve changed direction anyways...im keeping my ls1 i thought about it and decided i couldnt part with it..if i ever build a drag car..it will be a third gen...hands down
Old Apr 28, 2005 | 07:36 PM
68birdls1's Avatar
oh i missed the part where it said that you were doin this for a fourth gen lol. but i thought magnacharger came out with one for fourth gens?!? maybe look into that
