Need help with off idle stumble
I think it might be a problem with the carb, 670Holley Street Avenger, but i cant seem to find out what it be. Im using one the heaviest springs for the vacum secondaries since its a heavy truck. Everything else is the way it came out off the box except float and idle adujustments.
its a 350 with 9:1 cr
vortec heads
224/230 .477/.480 xe268 cam
RPM airgap manifold
headers
its in a 88 2wd 1/2 ton pickup
Base timing is set at 16* not sure on the total timing.
Thanks for any help
now that its metioned ill check the accelator pump cam clearance maybe its to loose, is there a spec for that?
Or he could get a road demon from barrygrant and have his drivabilty, hp and fuel economy!!!
