Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Small Block Chevy Engines
Old Jun 11, 2005 | 07:33 PM
_DOA_RA's Avatar
Default Small Block Chevy Engines
Can the ZZ383/425hp be dropped into 98 F-Body? If so what will need to be replaced to accomidate the xtra power? Suggestions, Comments Welcome.
GM ZZ383/425HP
http://www.gmpartsdepot.com/store/pr...Category_ID=63
Old Jun 11, 2005 | 10:47 PM
JD_AMG's Avatar
GM ZZ383/425HP
Most small blocks should fit.
But why are you swapping? It would be much cheaper to upgrade the LS1 thats in the car (assuming that this isnt some wrecked car).
But with 425hp, a new rear end (12 bolt) would probably be a smart replacement.
Old Jun 12, 2005 | 01:25 PM
Mangled03gmc's Avatar
Baltimore Whore
Old Jun 12, 2005 | 05:49 PM
_DOA_RA's Avatar
Originally Posted by mangledgmc03
This is true, but this one would go into a 98 Firebird. Can you say v-6?
Old Jun 12, 2005 | 08:00 PM
spootnik's Avatar
just do an ls1, you'll thank yourself the first time you change sparkplugs. have you ever tried to work on an LT1 car? No thanks.
