Turbo 454...
. Just thougt I'd throw this one out there to see if any of the turbo gurus might drop a line in this forum. Otherwise I'd have put it in the F/I forum. Agian, this would be intercooled (air), and have the necessary rotating assembly (duh). Probably have some iron heads and use ~8:1 compression. The main question though is what size turbo(s) would work for this application, single and/or dual? Depends on what you want out of it power-wise, a pair of 60s would be a tad small. I've only messed w/ a single turbo race BBF and haven't tackled a turbo BBC...yet.
On a big block of that size it should be pretty tame and spool fairly low in the rpm with the right exhaust housing. I doubt you will get much more response then that because you really haven't given the real details that matter, what kind of RPM? Stock heads? Power goals? Type of cam? transmission? rear gearing? Pictures of hot naked women? Induction style (Carb or injection)? and so on...
) It'll have some flat top pistons, netting ~8-8.5:1 compression. RPM air-gap intake, 750 carb (CSU blow thru setup for up to 1000 hp). All aeromotive fuel system... Want it to be just really torquey... Probably 750-ish hp I wouldn't think would be too exotic for a big block. Also intend to keep it under the 6500 rpm area to avoid having to use too much of a valve spring and to keep the off idle response. Heads would likely be AFR "stock replacement" oval ports, I think they're 305 cc intakes or so. No hot naked women, just my MP-t70 single turbo powered S-10 ridin' on the open trailer behind it.... This video of a '75 has convinced me that aerodynamics are for people that don't have power....
http://members.***.net/bstorment/Brian.wmv
Pt96 turbo on 509cid big block chevy.
