Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Engine going to dyno
Old Nov 21, 2005 | 07:43 PM
Cali99SS's Avatar
Default Engine going to dyno
Well my engine is finally going to the dyno. Only took 6 months to get built. It is a 385 running on pump gas. Engine builder says it should make just over 600hp. I am going to take a video camera. I will post videos asap.
http://i5.photobucket.com/albums/y19...1979/front.jpg
http://i5.photobucket.com/albums/y19...c1979/back.jpg
Old Nov 21, 2005 | 08:32 PM
Carbed4thGen's Avatar
Umm page i requested can not be found, try those links again!
Old Nov 21, 2005 | 08:51 PM
Cali99SS's Avatar
fixed should work now
Old Nov 22, 2005 | 12:43 AM
TimTaylor75's Avatar
Links now working. Definately keep us updated. A video would be pretty sweet as well. Nice job. Do you have a list of your parts used?
Old Nov 22, 2005 | 07:17 PM
Cali99SS's Avatar
Chevy 010 4 bolt main block, Eagle 3.75" cast crank, SRP 4.040" -25cc pistons, Crower 6.0" I-Beam 4340 Rods, Clevite H series bearings, ARP fasteners, Crower custom solid roller cam 282/286 .712 lift, Crower lifters w/ high pressure pin oiling, Chet Herbert 3/8" 4340 pushrods, Dart Iron Eagle Platinum 230cc heads CNC'd by M2 racing (320cfm@.700)(284cfm@.700 out of the box), Jesel Comp series offset shaft rockers, MSD Pro billet dist, MSD 6 digital+, MSD 8.5mm Super conductor wires, Professional Products Hurricane intake manifold, Custom headers yet to be built, and carb size yet to be determined.
Old Nov 22, 2005 | 11:11 PM
topend's Avatar
M2 made some good improvements on the port flow i see.The cam your using is a 282/286 at .050 lift???if so wow what a big cam.what rocker ratio are u using???
cant wait to see the dyno results
keep us posted
Old Nov 23, 2005 | 12:32 AM
Cali99SS's Avatar
Thats the advertised duration. It is 254/257 @.050. I am using 1.6:1 rockers. Builder says just over 600hp.
