camaro engine ideas
my project LS1 is currently in hold for my 95 Z
BUT
im also building a forged 355 SBC for use with blo-thru with cast iron heads
and a carburator and Holset turbocharger with a summit cam
the cost of the long block cost less than 1000$ with heads
for a 82 camaro with a "built" 700-r4 which should 500 lb/ft. torque
with a similar combo that i used to run but S/C it made about 525hp
but with the turbo it will make 700+pump gas
i think that should be nuff to take out a few LT1/LS1's
U SHOULD LOOK INTO BLOW-THRU
IMO its the cheapest reliable way to make power with a carb SBC
HELLO
