Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
85 camaro
Old Jan 8, 2006 | 06:20 PM
99stepside's Avatar
Default 85 camaro
i got a 85 z28 the other day. ive already ditched the stock 305. ive got a 350/turbo350 the im going to put in it. im going with a comp 280h, edelbrock air gap intake, some sort of headers, maybe some roller rockers, and a holley 700 double pumper. my question is should i use the heads that came on the camaro or the heads that came on my 1974 350?
Old Jan 8, 2006 | 07:48 PM
Camaro396's Avatar
use the ones off the 350 for sure, at least i would anyways..Im running a close set up as your talking about, I have a 350 2 bolt main with a stock bottom end, GM 2.02 heads ported and polished, Edelbrock RPM Air Gap intake, with a Edelbrock Performer RPM Cam, Procomp 1.6 roller rockers, a holly 750 double pumper and headers. I would think your 350 heads would be better.
Old Jan 9, 2006 | 08:11 AM
LETZ RUN's Avatar
i have some hooker shorty headers for a thirdgen if you are intrested ill let them go for 70 + shipping.
Old Jan 9, 2006 | 01:33 PM
rebersole2's Avatar
I have to agree with 396, use the 350 heads on the 350. The 305 heads are too restrictive on both the intake and the exhaust. They will work, but you would be hindering yourself of any potential gains from the cam and headers.
Old Jan 10, 2006 | 07:33 PM
99stepside's Avatar
what kind of shape are the headers in?
Old Jan 10, 2006 | 10:01 PM
sidewayz28's Avatar
go check out www.thirdgen.org they help a lot over there and most own third gen fbodies 305s/350s but i READ over their those 305 heads are not all that bad, go down to that site and post there theyd be happy to answer your questions...what car did you get the 350 out of ?
Old Jan 11, 2006 | 05:32 PM
99stepside's Avatar
the motor and tranny came out of a 74 gmc van.
Old Jan 15, 2006 | 12:58 AM
99stepside's Avatar
ive got the motor almost ready to go in the car. i was doing some measuring today and noticed that the 700r4 that i took out the car is about 3 inches longer than the turbo 350 that im putting back in it. am i going to need a different trans crossmember? also i guess my driveshaft will be too short now too. does anyone know for sure if im going to need different stuff? thanks for any help
Old Jan 19, 2006 | 04:14 PM
azzsmasher69's Avatar
yes you will need a longer driveshaft,i had an 85 that i put a th350 tranny in and had to modify the crossmember and bought a bracket for the torque arm that bolts to the tranny,but i would check to see if (bmr) might have crossmember and brackets,i know they do for 4 gen camaros
