dynamite sounding explosions coming from exhaust
Is your fuel pump mechanical or electrical? Do those old novas have something like a starter enable relay? Battery low? Bad grounds? Bad starter solenoid? Loose connections? Corroded connections? Broken wires from the ignition? Just some ideas off of the top of my head. Give me a couple more symptoms and we can narrow it down.
When I opened up the exaust on my car it popped and banged through the exaust due to a lean condition. Also, when a car sits but gets started on occasion but not "driven" it can cause plugs to foul up even if there new. You have to bring the motor up to temp n decent rpm so the crap gets burned off and does'nt settle on them. I've had that happen a few times. That also caused popping out the exaust, and it got harder and harder to start everytime I did till it finally would not start. Soon as I put fresh plugs, bam. Ran perfect again.The old ones seem to act up more as far as the little things go when there not driven that often. Mines an 80 and shes turning into an old b***h.
Sounds silly but the whole time it was my power safety switch on the back of the car. It didn't have a good connection apparently because I rewired it and I had juice after that. Shockingly it didn't take much for it to crank either. I took some timing back out of it and it ran great. I wonder what will happen next week when I crank it up. I should have my truck out of the paint booth by next week so I'll be taking the motor out anyway and putting it in the truck.
