flat top or dished pistons?
I've run flat tops because with a 64-67 cc heads they'll return 9.5-10:1 compression ratio in a 350, and with aluminum heads it will work fine on pump gas naturally aspirated. If you are planning a forced induction route dished may be the piston to use.
Derek
