Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
FI ZZ4 Engine Help!!!
Old Mar 15, 2006 | 09:52 PM
GBodyShop's Avatar
Default FI ZZ4 Engine Help!!!
Have a job on a ZZ4 engine. The owner wants a FI on his ZZ4 and looking for the best FI set up that will work the best for this engine. Any help will be good. ZZ4 is a 355 Hp and 405 lbs of Tq.
I suggest a Speed Density TPI with a custom chip from Street & Performace.
The car will be used as strret and strip.
Thanks for anyones help.
Jose Luis
1987 Monte Aero
1987 ELKY
1986 442
Old Mar 16, 2006 | 12:42 AM
91Z28's Avatar
I use a Holley Stealth Ram on mine and it runs hard. If you put a TPI on there it'd choke out quite a bit of hp.
Old Mar 16, 2006 | 12:51 PM
orange88's Avatar
id run a tpis mini-ram
Old Mar 16, 2006 | 01:06 PM
91Z28's Avatar
Stealth Ram is a much better fit on a stock ZZ4 than a Miniram since the Miniram only outperforms the HSR above 7k RPMs on a 350. There was a guy on the LS1GTO forums with the same combo as me with a more restrictive exhaust who made 292rwhp and 367rwtq. Not going to see that kind of torque with a miniram on a ZZ4.
Old Mar 16, 2006 | 02:19 PM
orange88's Avatar
on my old combo i had a zz4 and mini ram thru a 700r4 and made 315hp and 355 tq.
unless the car weighs over 4000lb you shouldent need anymore tq
Old Mar 16, 2006 | 03:54 PM
DeltaT's Avatar
Holley Stealth Ram with the Pro Software and the wideband O2 option. Or if he wants a single plane style, the Holley MPFI with the same options. Summit has the best prices.
Jim
