Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
1969 427 bbc Specs
Old Apr 20, 2006 | 05:37 PM
Chevyguy04's Avatar
Default 1969 427 bbc Specs
I was wondering if anyone has the specs for a L72 427, or the ZL1 427?
Or where i can find the specs for these motors?
I can get an L88 427 from 1968 and want to make it have the power of at least the L72 motor, i am putting it in a 1969 Camaro COPO clone.
Also wondering if anyone knows how much torque the L88 has? i know it is a 390HP motor
Thank you any help is appreciated.
Old Apr 22, 2006 | 07:17 PM
Sparky65's Avatar
First, the L36 is a 390 HP engine, the L88 is factory rated at 430 HP but more like 560 HP @ 6500 RPM. Heads, cam, pistons and inake will basically turn an L36 into an L72 although the L36 is a two-bolt main block and the L72 is 4-bolt. With all the cars listed in your signature, I would expect you to know this.
Old Apr 23, 2006 | 03:39 PM
Chevyguy04's Avatar
Yes i did realize i screwed up and said L88 instead of L36.
Does anyone have any good websites with chevy engine information?
appreciate anything right now
Old Apr 24, 2006 | 08:49 PM
TTSSZ's Avatar
the l-36 is a 390/385hp Holly or Q-jet 4 brl carb, high-lift hyd cam, small port cast irn heads, 10.25:1 cr 2 bolt mains . forged crank
The l-72 - 425hp holly 800CFM 4-bbl carb, mech cam, big port cast iron heads. 11:1cr. 4 bolt main, forged tuftrided crank, forged pistons, alum high rise intake manifold.
I have one and untuned it did 350rwhp 390wrtk with headers.
seemed a little tired, my ls1 did 327/337 stock.
(350/390rw is about 425 crank Hp 490 crank TK)
-Put a 200 shot on it to bring it up to snuff.-
the L-71 - same but with 3 2bbr carbs
L-89 same as l-71 but with aluminum closed chamber heads
L-88 430hp holley 850cfm 4 bbl carb, high lift mech. cam alum heads (open chamber in 69), 12.5:1 cr, 4-bolt, forged tuftrided crank, forged pistons, floting wrist pins, 1/16" compression rings, 7/16" pushrods, open plenum intake manifold
z-l1 430 hp same as L-88 but with aluminum cylinder block
I have a set of 074 L-88 heads I was going to put on my l-72 but I think I am going to sell them and get a set of a.f.r. heads. Let me know if you might want them.
Old Apr 27, 2006 | 09:21 AM
Chevyguy04's Avatar
thanks for the info
anyone else have any input????
Old Apr 30, 2006 | 08:27 PM
firebird69racer's Avatar
check out these sites
http://www.nastyz28.com/sbchevy/sblock.html#camaro
http://www.chevy-camaro.com/
Wade
Old May 2, 2006 | 12:22 AM
67SS&99SS's Avatar
www.yenko.net
